gmanor77
  1. Hi, The inverter did not arrive yet, I will update when it does. If you have 220v 60hz electricity voltage in your home then you can try converting it to 110v with a simple voltage converter, it won't change the electrical frequency. Then you will have 110v 60hz and you be able to try the PLM.
  2. The problem right now is the shipping time from china... It will take up to a month to arrive...
  3. Hi, I just bought 110v, 60Hz inverter from ebay. The inverter takes 12V DC as input and output 110v 60Hz. I have 220v to 12V DC converter in my house. When the inverter will arrive I will try to connect it and will try my Insteon Smoke Bridge (This one is like the PLM, it works only via 110v 60Hz - I tried connecting it using 220V to 110V and it didn't work cause the frequency is 50Hz on the output) - If it will work with the smoke bridge then I think it will work with the PLM - I will update. Thanks.
  4. Thanks for the answer. I understand that the PLM can send commands using the power cables and via wireless com. If I am using the 220v to 110v adapter - will the PLM succeed sending commands wirelessly? I think it will be enough for my home. Thanks.
  5. Hello, I am also from Israel. I am using the insteon hub. Thinking to move to the ISY994i. About the 60Hz problem, won't this solve the problem? http://img.dxcdn.com/productimages/sku_14322_1.jpg Also, can some one explain to me the diffrence between the ISY994i and the ISY99? Thanks.
  6. Hello, I am using the Insteon hub with 4 micro on/off modules (2443-222), wireless open/close sensor (2843-222),mini remote 4 scene (2342-232) and smoke bridge (2982-222). I am thinking to move to the ISY994i because I understand that with the ISY994i I can make scene and events with conditions and trigers (similar to house-link software). 2 questions: 1. If I buy the ISY994i with Insteon serial plm, will I be able to use my exiting modules (that I mention above)? 2. Will I be able to change the micro modules setting from the software - because the modules are installed behind the ceiling lamps, I can't reach them - can I change the modules settings, like switch type connected (latch, 3-way latch, single momenteay) from the software? otherwise I will need to take off the ceiling lamps to change settings from the module. Thanks.
