steveaz
Everything posted by steveaz
  1. I will give these access points a try. We do have 3 phase power, so it may be a challenge. I'll let you know how it turns out. thanks,
  2. you mention two properly placed access points to couple the phases. What is an access point and what is its part number? Do you have a suggestion as to proper placement for them?
  3. it was an X10 coupler/repeater. It has been removed. I am still getting intermittent operation. For instance, I have a 2334 8 button keypad hooked up on one side of the house which works OK. I have installed another 2334 on the other side of the house and it won't link. the led blinks green, but does not sync and finally it turns red. There are two switches on that side of the house that do work. Thanks
  4. adding the device next to plm allowed me to sync however some insteon devices operate intermittently. I have a phase coupler installed for my old X10 system where separate phases was a big problem. Can this coupler be causing the intermittent instenon operation? Should I remove it?
  5. plugging a unit in the same outlet caused it to start linking! Why? thank you.
  6. I have installed a new isy 994i. I have followed instructions, but new insteon control modules (for instance 2634-222)will not link up.
