Andreas
  1. No sir, No conditions in the programs folder. I was wondering if it could have something to do with my plm? when i go to diagnostics to check its links. It is not linked to anything, and when i try to reset it, it gives me the following error in this pic. I just bought the plm is it possible that it is not working?? when i look for plm links table it has a funny unknown 0200 thing on the buttom I apreciate all these swift replys LeeG
  2. It seems I have a problem with the ISY not responding to some of the commands.. Here are some screen shots, when i Turn the device Fast On, it does not execute the IF command. It is Saved. The strange thing is that this is the same with timers. e.g if 6.00 am turn off light x. It also does not send notifications very well, but if i do a timer that says, if status garage light is on, turn off after 10 minutes then it does do that! what the heck is going on here??
  3. LeeG I checked the event viewer on lvl. 3 and it seems that I am double tapping it correctly. Thats why i dont understand what i am doing wrong. I following exactly this code and its just not turning on switch b, unless the switch i do fast on with is already "on" Im having trouble with most programming and im starting to think it might be the system..
  4. Dear Universal-Devices Forum. I have a questions about the following programming. I am sure that the ISY is working correctly and it is I that need to be enlighten on the workings of the ISY. When i program a switch to control another switch with the Fast on Command. It only does so when the the switch is already on. (If the switch is off, and i do a fast on action) the other switch does not respond. Code looks like this: If Control 'Garage' is switched Fast on Then Set 'Outside Pool Light' On How do i make the Fast on activate the code, no matter if the switch is on or off? Thanks in advance!
