Mdf
  1. It's paired. and reading the current power usage.
  2. I guess I should have read the documentation first . I'm now using http://isy.universal-devices.com/994i/zs/dashboard.jnlp to do this. WIll let you know how it goes. Ed
  3. Hi Michel, Binoculars where? I don't see any binocular icon anywhere (P.S. I'm running Java under safari on my Macbook Air). by the way, Here is the status I get back from ...rest/zb ( N/A3A3A0013500100F716C32501 Thanks, Ed
  4. I was just on the phone with PGE trying to get my ISY-994izs paired. From their end they see the meter able to talk to the the ISY-994izs confirming (according to PGE) that the EUID and the (24 byte) Install Code are correct. But though the ISY is scanning on all channels it never seems to pair with the meter and simple has a network status of Scanning Complete|Node:Null |Channel: Null| Power: Null. I rebooted the ISY and PGE tried pairing again, but that didn't help. My ISY-994izs is about 2 feet from the meter. Any suggestions of what I should try next? Thanks, Ed
  5. I'm in the process of trying to get my meter set up with PGE as well. Should I be using a 24 or 32 byte Install Code? (I note that there was an earlier part of the thread that said one needs to use 24 byte codes which is what I'm using. ). What's the best way to figure out how far each side it is getting in the pairing process? I continue to only get "Scan Complete | Node: null | Channel: null | Power: Null". My ISY-994Izs is about 2 feet from my meter.
  6. This is just a light in my office (where I'm playing with the motion sensors). When I do a "Run Then" exactly what you expect to happen happens (i.e. my office light blinks on and off). Separately, anyone know if there exists some where a list of the latest and great version numbers of various devices? Is there V.00 version number on my motion sensors the right version number? Thanks for all your help. MDF
  7. I have a new 994i (latest official release firmware 4.0.5) and new 2842-222 motion sensors (v.00, which seems like a bit of an odd version number). I happily have the motion sensors linked to the ISY, I can configure them (I have jumper 5 installed), and I can set them to be controllers for scenes just fine, and they happily control those scenes. But what I've been absolutely unable to get to work are even the simplest programs triggered by motion sensors. I figure I'm missing something simple, but I've yet to figure out what it is. I have lots of other non-motion sensor programs that work (e.g. things driven by sunrise, sunset, etc). As an example, the following simply program never runs, even though I see the motion LED blink. I have the Motion sensor set for On-only, so I don't think an accidental off-command from the motion sensor is causing me problems (and besides in the Summary tab, I never see the program as run). I've checked and double checked that the program is enabled and is in a folder that has no conditions on it (other things in the folder run happily). If Control '3F-Master Bath-Motion-Sensor' is switched On Then Set '3F / Office / 3F-Office-Chandelier-DIM@Door' 100% Wait 4 seconds Set '3F / Office / 3F-Office-Chandelier-DIM@Door' Off Else - No Actions - (To add one, press 'Action') Other data: I have 100+ dual-band devices in the house, and as I play with the motion sensor pretty much nothing else is happening, and I'm about 10 feet from a dual-band switch. I can get "current State" responses from queries to the sensor's Low-Bat, but not to Dusk or Sensor, which I find a bit odd, as sensor is awake I believe. So I'm sure I'm doing something wrong, but I have no idea what it is at this point. Looking forward to finding out where I'm being stupid. Thanks, MDF
