kaveh
Everything posted by kaveh
  1. The purpose is to adjust the on levels of the lights in a scene such that at night only certain lights in that scene get turned on. 1% still seems like it would try to power the light. It'd be nice to keep it off.
  2. This doesn't make sense. Seems like a bug.
  3. Basically I'm using this dimmer as a controller to a scene. The dimmer itself also controls a load (light). I have a program set to turn the on-levels of this scene to a lower setting in the middle of the night (so when you get up you don't blind yourself with lights) and back up to the full setting during the day.
  4. It goes to the local on level, 1%. v.41
  5. No I don't think this is it either. As I said, if I set the switch's local ON level to 1% in the ISY controller, it will only turn it on to 1%.
  6. I have a weird issue where if I set the on level of a 2477D dimmer to 1%, everything works as expected and when I go hit the on button the dimmer, it only moves to 1%. However, if I set the on level of the dimmer to 0% in the ISY, then go to hit the on button on the dimmer, the dimmer goes full-on. Is this a known issue? Is there any way around this?
