Rich33
Everything posted by Rich33
  1. Thank you Michael for sending me the link to your write up on the wiki. I'm afraid what you're doing is a little beyond me and most of the capabilities that the NW module will provide me I'm not ready for to justify the cost . I'm going to keep my fingers crossed I find another solution since this did work once before. If not though, I may go this route. Again, thank you. I appreciate the help.
  2. I tried using <body> text </body> but that didn't help... I still couldn't read the text msg. I don't know html... are there better tags to use? Thx.
  3. Thank you Andyf0! I'm making progress!!! I padded my message but unfortunately that didn't work however, it led me to try sending my message as html and xml. In both of those case it showed the sender as "alerts@uni..." and showed grouped my messages! I wasn't able to read my messages though... I'm assuming because it was properly formatted as html or xml so I'll try that next after I figure out what the proper tags should be.
  4. Thank you all for your responses. I'm using my cellphone@tmomail.net as the address to send texts to. I'm pretty sure this is what is recommended... and it's working other than the sender id MWareman, could u pls provide a pointer on how I could use network based push notifications. I'd really like to solve this. Thanks.
  5. Hi, I'm using txt msg alerts to let me know when certain events happen. I seem to remember all of my msgs coming from an "alerts@..." source but regardless, they always came from the same source each time so that all of my alerts were in the same sender log on my cell phone. Now, every message comes from a different sender with the sender being of the form 9489, 9490, 9491, etc. I would like to get these back to being all from the same sender so they're all grouped together and I have a history of alerts in one place. I'm currently on T-mobile. I was using AT&T a while back but don't recall if this problem started around the same time I switched providers (I've been living with this for a while). I appreciate any advice you have. Thanks.
  6. Hi. No, I have never had a problem with the button popping off. I did insert a double clear lens for rigidity though. I used one of the lenses from the 6 button frame for this. I would try that if you're not already doing doing so. I hope that helps.
  7. Sorry for the delay. This turned out to be very easy to do. First, as indicated above the wide button installs over adjacent smaller buttons so physically it is as simple as snapping the wide button in place. One thing I didn't like about this though is that the backlighting was not uniform across the wide plate because of the two smaller frames. To get around this I cut the inside frames with wire cutters and then installed the large clear lens for stability before installing the button. These pictures make this a littler clearer. Original Frames New 7 button frame after cuts Once the frame is installed all you need to do is cross-link the adjacent controls that you want to act as one so that both are controllers and responders to the same scenes. I hope this helps.
  8. Thank you all. Knowing this is possible, I will proceed and will post my results and a simple how-to guide in a few weeks when I return. For reference, here's the link EricK was referring to from Stusviews. http://www.smarthome.com/forum/topic.asp?TOPIC_ID=13822 Thanks also to Stusviews for help finding the link.
  9. EricK, I'm having trouble finding Stu to look at his post... would u have a link? Thanks.
  10. Thanks. I'll order the 8 button conversion kit and give it a try. Between shipping and business travel it will be a couple of weeks before I anticipate doing this but I'll post pics and a summary when I do.
  11. Hi. I have a 6-Button Keypad dimmer model 2334. I believe I can convert it to an 8-button keypad but I'd really like to convert it to a 7-button keypad by leaving the large button on top as is and only converting the bottom large button to two smaller buttons. Is this possible? Thanks.
