kevinkaz
  1. Just to clarify. Did you try to use the find/replace?
  2. JBanaszak started following kevinkaz
  3. I have two ISY-994i PRO units. I migrated the z-wave devices that would not function on a ISY-994i Pro unit with firmware version 5.1.0 to my second ISY-994i Pro unit running version 5.0.15A. The migrated z-wave devices now seem to be functioning. I have one exception. I received a new z-wave ZooZ outdoor motion sensor, ZSE29 version 2.0, which does function from either of the firmware versions mentioned above but I can not set any z-wave configuration parameters. Wed 08/12/2020 19:06:07 : [UZW-CMD 51 ] [ZWCMD cmd.51] Wed 08/12/2020 19:06:16 : [UZW-CMD 51 ] [ZWCMD cmd.51] Wed 08/12/2020 19:06:24 : [ZWAVE-TE ] [70/05] CC=0x70 cmd=0x05 [05] ACK,AUTO,EXPLORE To=0x10 Wed 08/12/2020 19:06:24 : [ZWAVE-TX ZW016_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x10 Wed 08/12/2020 19:06:28 : [ZW-TX-FAILED] enc=Fail uid=16.0 cmd=0x70.05 CONFIGURATION Wed 08/12/2020 19:06:28 : [ZWAVE-TX-E ] ZWAVE-WAIT Waiting for retry 1 of 2 Wed 08/12/2020 19:06:29 : [ZWAVE-TE ] [70/05] CC=0x70 cmd=0x05 [05] ACK,AUTO,EXPLORE To=0x10 Wed 08/12/2020 19:06:29 : [ZWAVE-TX ZW016_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x10 Wed 08/12/2020 19:06:29 : [ZWAVE-RX-ST ] No Device Ack Wed 08/12/2020 19:06:29 : [D2D EVENT ] Event [ZW016_1] [ERR] [1] uom=0 prec=-1 Wed 08/12/2020 19:06:29 : [ ZW016_1] ERR 1 Wed 08/12/2020 19:06:29 : [ZW-TX-FAILED] enc=Fail uid=16.0 cmd=0x70.05 CONFIGURATION Wed 08/12/2020 19:06:29 : [ZWAVE-TX-E ] ZWAVE-WAIT Waiting for retry 2 of 2 Wed 08/12/2020 19:06:30 : [ZWAVE-TE ] [70/05] CC=0x70 cmd=0x05 [05] ACK,AUTO,EXPLORE To=0x10 Wed 08/12/2020 19:06:30 : [ZWAVE-TX ZW016_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x10 Wed 08/12/2020 19:06:34 : [ZWAVE-RX-ST ] No Device Ack Wed 08/12/2020 19:06:34 : [ZW-TX-FAILED] enc=Fail uid=16.0 cmd=0x70.05 CONFIGURATION Wed 08/12/2020 19:06:34 : [UZW-CMD 28 ERR ] Query Config : ZW016_118 param 5
  4. So far all of the issues I have experiencing are with the Aeon Labs z-wave devices. ZooZ z-wave motion sensors are functioning. GE z-wave lamp module functioning. Insteon device are functioning.
  5. Aeon Labs Appliance switch Model DSC061606-ZWUS zwave synchronize command nuisance: Device identifies & functions correctly Issuing a device zwave synchronize command will: 1-> move the device to the master folder, from a sub-folder 2-> then the device will be renamed to the to the default name 3-> the device is removed from all scenes
  6. Reboot has not corrected this issue. Upgraded yesterday. After syncing zwave nodes all then renaming the devices back to my method most are functioning but the two Aeon Labs MultiSensor devices I must perform a zwave synchronize to update the ISY.. Event viewer set to level 3 Log is only one zwave device but both exhibit the same issue. Aeon Labs MultiSensor L3.txt Message when only PIR enabled Mon 08/03/2020 13:59:01 : [ZWAVE-RX ZW119_1] [20/01] Basic Set val=0xFF ACK,AUTO,EXPLORE From=0x77 Message after 20 second timeout Mon 08/03/2020 14:02:11 : [ZWAVE-RX ZW119_1] [20/01] Basic Set val=0x00 ACK,AUTO,EXPLORE From=0x77 ISY status for device does not update.
  7. Device type [10.1] (2420M) versus [10.3] (2420M-SP) What are the differences? How do I known which to use? Is there a help / explanation of device types posted somewhere?
  8. Can the EZSwitch30 dual relays be controlled independently via the ISY-99?
  9. When using Set Fade Down the ISY does not show the correct status of the device.
  10. kevinkaz replied to gmurch's topic in ISY994
    Same with my ISY. A reboot corrected the issue. nsteon_UD v.2,7.6
