wayneph
  1. wayneph replied to wayneph's topic in Polisy
    Thanks. Once I hear from support and get the files/new ssd I'll see what I can do. While I wait, I just installed Home Assistant on a Raspberry Pi I had sitting around. Definitely not the plan for the weekend.
  2. wayneph replied to wayneph's topic in Polisy
    That doesn't sound fun... And I assume that means I need a backup. The last one I have looks like it was from when I upgraded to 5.5 back in 2023. Luckily I don't think I've changed much over the last 3 years, but I'm sure there was something.
  3. wayneph posted a topic in Polisy
    As part of trying to get all of my devices updated, I attempted to update the OS on my Polisy, but it never came back... I had logged into the isy through the portal and selected the update option. I think it said I was on 5.5.6 (or something close) and would update to 5.9.x. It told me it could take up to 30 minutes so I just let it go. Prior to the update, I could see the polisy on the IoX Launcher as well. About 45 minutes later, I went back to the portal to confirm everything went well and it said the ISY was offline. I attempted connecting through the mobile phone app and tried to find it on the IoX Launcher, but nothing showed up, I attempted to ssh into the device, but it said there was no route. I have checked my DHCP logs and after restarting the device twice (by pulling the power cord since the multifunction button doesn't appear to be doing anything) don't see the IP request ever getting to DHCP. Each time I power it on, it the device briefly shows 3 lights on the front, but quickly goes to just a single solid first light on the left. From everything I can find, that's a good sign, but nothing else seems to be able to get to it. I'm still scouring the forum and wiki, but am quickly running out of ideas. I've also sent this to support, but trying to come up with ideas to get back online...
  4. Just now getting started with Polyglot, but I think I'm in the same boat. Updated my polisy to 5.5.5 today. I was able to get into the polygot3 site. Added my local isy and then tried adding a couple of the free node servers to get a feel for them. It seemed to add one or two (one was showing up in the admin console) but then became unresponsive. I rebooted the polisy and then couldn't get into polygot3 anymore. As others have mentioned, I can get into the old polygot site and the admin console, but nothing for pg3.
  5. So... I had only looked online (not from the app) yesterday. It looks like Alexa is correctly picking them up as Fans which is good news. Since I primarily use Google Home from the phones, and Alexa from Echo/FireTV Remotes, I haven't used the Alexa app much since I can remove/update devices from the Alexa website. It seems like my problem now is just speaking clear English. I can "Set Office Fan to 2" and get it to work, but "Set Office Fan to Medium" does not. I'll have to play with a few different configurations of Spokens and Scenes to see which combination keeps my wife happy. Maybe I just go back to having a 'default' speed for each of the fans, and just use a scene. I can turn the fan on and off via voice, but I'd have to use a button/app if I want to change the speeds. That would probably keep things the simplest.
  6. Thanks @Javi, that gives me one more idea on how to set up. I've got 7 rooms with FanLincs and KPLs so I'll get to set these up multiple times. Wish there was a little more logic available in the programs for switches/nested if/else interrogation as opposed to needing 4 separate programs to monitor the status. That being said... My bigger problem right now is getting the FanLincs just added to Alexa responding like fans. I've deleted and added 2 or 3 times today with different names and they still aren't working.
  7. I've unfortunately already done that as well. When I first added it back in, I ended up with duplicates, so I had to clean out from alexa.amazon.com to get rid of the dreaded "multiple devices with the same name" message. Looking at the devices list, I have confirmed that the each fan motor's ISY Device address 'XX XX XX 2' only exists once. (Since I don't have more than one spoken for each one.) Additionally, I've verified there are no duplicate names so it isn't, or shouldn't be, finding the wrong device. What I'm not sure of... is whether or not the Fan Motor would also need to be a controller for it to "just work". Since only the buttons are controllers, I'm not sure that the scene would still stay in sync without something else if the device is controlled with voice. I've temporarily paused any more changes until I can figure out what went wrong with Alexa.
  8. Excellent. Up front, I'll probably try using the Network Resource as that will let me get something working pretty quickly. I haven't used any before, but the example above looks pretty self explanatory. I may still investigate setting up my own Python node server afterwards, but it will likely depend on free time. Thanks all.
  9. I was playing with one of my Fanlics/KPLs/Alexa to try and come up with the best combination to keep everything in sync and ended up breaking the Fanlinc integration with Alexa. At this point, Alexa discovers the device, but I am only able to turn it on (HIGH) and off. Any attempts to set MEDIUM/LOW (which previously worked) are now met with "I don't know how to set Fan Name to that setting." I've tried using a new name that doesn't match anything else in the system, and (stupidly) a removing/readding a second Fanlic which broke it as well. I have confirmed that I am choosing the 'Fan' device type on the ISY portal, but it's as if it isn't getting sent correctly to Amazon when she discovers the devices. Any suggestions? Kind of separate, but... What is the best way to set up Fans with Alexa/GH and KPLs? If I control via Voice, my scenes are getting out of Sync. I just saw the update for 5.x scenes that would let me minimize 3 scenes into 1 for Fans, but I'm not sure it will actually help. Currently I have program monitoring Fan State and setting the scene after a voice command. It works most of the time, but occasionally something gets off and ISY puts them in a loop where they cycle between the different states. Was hoping the new single scene would help alleviate that, but now I'm not sure if I can use the helper programs since I can't set scene to "Medium". I think I need to go back to my original 3 scene setup with helper programs, but if I can't get the devices to add back correctly, it won't really matter...
  10. Don't have any Z-wave at this point. Everything is still INSTEON. I do c++ programming for a living, so the APIs don't scare me. I've done some python and am getting more and more familiar with it. If there is a template out there, I should be able to do what I need. I was just hoping to find one to help with and/or modify if someone had already started down the path so I wasn't necessarily starting "from scratch". My main problem is that I don't want to spend the time on the ladder to get everything installed, so I'm leaning toward an existing solution that I can integrate. The companies I'm looking at all have trim matching tracks and can run the main wiring in the attic in a day or two. It would take me significantly more time to get it all set up. I'm not planning on having the ISY control the individual lights. I more just want to tie them into KPL switches and a handful of programs on the ISY for scheduling, etc... The one I'm looking at can control individual bulbs, so I may set up some accent and/or security lighting the rest of the year when I'm running holiday lights.
  11. Howdy all... I'm looking at having some permanent Christmas Lights installed and was curious if anyone has tied some into ISY for control. Most of them come with their own Android/iPhone apps, but I'd like to be able to tie it in with a switch and other ISY scenes. I've talked to Jellyfish Lighting and he said they had an API I could connect into. Trimlights and Everlights are the other two that install near me. Just curious if anyone else has gone down this route, or if I'm staring from scratch. All 3 products are relatively similar, so I'm leaning towards the API at this point, but if there is an ISY integration started with one of the others, I'd consider it as well. Thanks, Wayne
  12. Thank you both. I setup the spokens directly in the Portal, so they didn't come across automatically. I was flying through the posts/wikis just trying to the Alexa set up, so I probably didn't take the time to consider benefits to doing some additional leg work on the isy before pulling them all together. I just noticed that "room" is required for Google and I didn't populate it for Alexa, so even if the copy was there, I bet I would still have issues. Guess it's time to be glad I have dual monitors so I can have Alexa up on one and edit Google on the other. It's probably the fastest option at this point. Thanks again.
  13. I just went through and setup about 50 scenes in the Alexa/Echo config. I also have Android phones, so I'd like to set them up for Google Home as well. Is there a way to "copy" the spoken configuration from one to the other? Or do I need to recreate them all manually? Thanks, Wayne
  14. Just more proof for me that I needed to ask the question... I'm guessing that I would max out at 3 or 4 cameras, although if everything goes well I suppose it could go up. Ultimately, I would like to go wired, but since I am retrofitting this into a 2 story house, I have limited options based on access to certain areas. (When I replaced my HVAC, I lost my Insteon thermostat because I couldn't get 7-wire to the main level for the 2-stage control.) I was hoping to add Mobilinc for the camera access (and to get more remote device control) but as an Android user, it appears that Mobilinc won't help me with cameras. Ideally I could control the ISY and review cameras in a single application, but that may not happen with Android. At this point, my main goal is reviewing cameras after events. With the season of UPS/FedEx leaving packages on doorsteps, I'm really looking for capturing images should something go missing. Long term, I can envision wanting to control the cameras with ISY, but I think I need to start with the basics before trying to over-complicate things. I've had a few thoughts about where to locate the recording device to try and protect the device, but I haven't fully thought through it. I have a small MoCA network (serves to FireTVs that stream my TV Service from HDHomerun) that could be used to help keep the device away from the rest of my computer equipment. It's better than just wireless and allowed me to use the existing cable line for areas I couldn't get new cat5e/6 runs to. Guess I have some more research to do. We'll see if anything looks good on Cyber Monday specials.
  15. I am trying to get started with security cameras and I'm not really sure which way to go. I've got ISY with Insteon, but am pretty much just using it with switches and lamp modules at this point, but want to expand it more. Additionally, I was looking to add a motion sensor to the porch to turn on the lights as someone approaches the front door. Since there are similar requirements, trigger an action when something is moving, I was hoping to kill two birds with one stone. Are there any recommendations for products/configurations that are relatively simple to setup? I've looked at the Insteon cameras, as well as a couple IP cameras and really don't know which way to go from here. Is there anything else that I should be considering? (Or not be considering to simplify things?) I apologize for the open ended question, but I really wasn't sure how to hone in on anything more specific. Wayne
