MyHome
  1. Thanks...I will reach out to their tech support.
  2. Hi Paul, Thanks for this insight. The installer did not know this information. However, to have it control my new Google Camera which was sent to me by ADT, they were able to have Google Home see the status of the panel and the devices. Theoretically, I can have the camera turn on only when the alarm is set to armed/away. There is a bug in the programming though. I was hopeful that I would be able to see the alarm status in the ISY so that I could have other devices turn on or off when the panel is set for Away. Any additional thoughts? Thanks, Mitchell
  3. I have an ADT Control system with keypadin my home. I would like to be able to see the status of the system (armed away, home) to control devices that I already have on my eisy. Is there a simple way to accomplish this?
  4. Thanks! I will see how hard it is to install on my NAS.
  5. I would like to control my eisy devices with Siri. I have a Synology server and believe I can install either Homebridge or Home assistant. What is the best path forward so I can control eisy-based devices with Siri? Note, in parallel, I am running SmartThings devices on a separate system.
  6. Here is what happened: the light switch did not turn on at Sunset. I ran the "If" after sunset and then it turned on. However, it automatically turned off at 11pm. Therefore, the ISY recognized the command. What do you think is going on?
  7. Thanks for pointing me to the Log. The routine for the device did not try to execute. I looked at the flow in the folder, and the folder has 3 routines that didn't work since the outside plugs are unplugged as we are having repairs in our back yard. One of them prior to an error and 2 after the error didn't run. I disabled the routines that should not run, and I can allow it to run this evening and see what the log says. Is there an instruction that if there is an error, then it should proceed? Any other thoughts?
  8. Here is the program:
  9. There is no condition in the folder, and, it is enabled. Interestingly, it turned off at the proper time. It started when I moved the ISY temporarily to a new location. I moved it back to the original location and am having the current problem. Strange since I can manually turn it on from the dashboard, but it does not turn on automatically. I thought I would recreate the routine from another folder and see what happens. LMK if you have any other ideas.
  10. I have an ISY994i that has been working very well. Most of my programs are working. However, for some reason, several in one folder, but not all of them, have stopped working. I can manually do a "Run" for the program and it does fine, but on it's own, it does not work. The programs are simple. If between sunset and 11pm, Then turn ON, Else turn Off. The devices are Insteon. Any thoughts?
  11. MyHome replied to MyHome's topic in eisy
    Thanks both. I believe that it uses Wi-Fi. I am not sure I understand MrBill’s response. Is there somewhere I can read a briefing on loX devices? Thanks.
  12. MyHome posted a topic in eisy
    Is there a simple path to get a Meross device to work on the eisy? I have several in use at a cottage that has an Aeotec hub, and plan to put in the eisy next month for going forward use.
  13. MyHome replied to MyHome's topic in ISY994
    I just re-read this. I am not sure I understand the "cTrue". Can you provide more information on the use of a constant? Thanks.
  14. Thanks. I will change the power supply first, and come back if the power supply or changing the SD card do not work.
  15. Thanks. Attached is the recent part of the error log. I look forward to your thoughts. ISY Error Log.v5.3.0__Sat 2023.07.15 03.15.31 PM Recent Only.txt
