khisanthax
Everything posted by khisanthax
  1. My filterlinc doesn't fit into the appliancelinc because of bulk do you have a recommendation or know of a device that has both built into one?
  2. What I noticed was that I had some communication failure with the appliancelinc, it still worked so far but I couldn't query it and it wouldn't show when it was on. The plm is not on the filtered side of the filterlinc so that should be fine, and the isy being powered on the filtered line shouldn't matter either, right? Right now my appliancelinc is running my PC, but I would like to use a filterlinc for my PC since I imagine that it must put out noise or suck signal strength, right?
  3. If I place an appliancelinc after (on the filtered side) a filterlinc, will I have problems communicating with the appliancelinc? Will any insteon devices placed after (on the filtered side) the filterlinc have problems communicating with the isy?
  4. Lol I feel the same way sometimes. I've got them turning on with one program using an or statement for either motion sensor. The off is giving me problems. If I use an and statement for control switch off they don't switch off. If I use (control switch off and status off ) or ( status off and control switch off ) where the two parens are the different motion sensors they still don't turn off. Looking at your sample why do you put the then statement in a separate program? And yes everything is pointing to a scene not directly to a device.
  5. so I'm trying to use two moron sensors in the kitchen so that if one sensor is triggered the light turns on but will only go off if both motion sensors are switched off. I tried using and with parentheses placing both control switch with an and operation inside for turning off the scene as well as a And parentheses with an or operation on the inside for turning on the lights bit neither seem to work. Prior to the and parenthesis there is a date/time variable followed by the control switch and then a variable. Did I Do it wrong? Is there a better way too use two or more sensors in one room? Does order Matter inside or outside the parentheses?
  6. 'm sorry I meant appliancelinc not powerlinc. I was thinking of putting the filter on the wall outlet and then put the ups with two power strips and all the devices connected to the two power strips. If any insteon devices go after the filter will it mess with communications?
  7. So from what I read the filter cause between the powerline and the device. In my case I'm not trying to control appliances, yet, just the lights in the room with the wall switch insteon controller. So, where my av and networking equipment I just plug it into the wall and plug the ups into the filter with all the devices plugged into the ups? The subwoofer, not a powerful one, is likewise plugged into the ups. The only appliance problem I had was with a powerlinc connected to a monitor. When they were plugged into a power strips behind the ups none of the switchlincs were getting signals.
  8. I imagine I have a basic home theater setup: surround sound receiver, camera system, converter box, router, nas drive, tv and a pc connected to two power strip connected to a ups. I get intermittent devices not working usually the same two or three wall switches. If I move the isy and plm I usually get worse results. Where inthechain should I place a noise filter for insteon? And because so much is plugged in near each other will i need more than one?
  9. What I Didn't see was code for direction. I liked that Lee used variables but it also looks like the order of the trigger doesn't matter so long as both ms are turned on that's all that matters. For me turning on 1 then 2 is different than 2 then 1. Did I Read the code wrong?
  10. So I was wondering if any one has tried using multiple motion sensors to determine direction? For example, walking towards a room triggers multiple sensors in order which let's you know what room or area to turn lights on for. Or multiple sensors to accurately determine motion in a large room?
  11. Title pretty much says it all. I had a complex program and for whatever reason the kitchen motion sensor wasn't turning on the kitchen lights. I checked and the motion sensor is going on and the program is running to turn on the lights but it never turns on. Same problem with the hallway program and bathroom. This is my event log if it helps: Thu 10/30/2014 15:44:09 : [ 27 91 81 1] DON 1 Thu 10/30/2014 15:44:09 : [ 27 91 81 1] ST 255 Thu 10/30/2014 15:46:20 : [ 24 A BB 1] DOF 0 Thu 10/30/2014 15:46:20 : [ 24 A BB 1] ST 0 Thu 10/30/2014 15:47:18 : [ 27 91 81 1] DOF 1 Thu 10/30/2014 15:47:18 : [ 27 91 81 1] ST 0 Thu 10/30/2014 15:48:58 : [ 27 91 81 1] DON 1 Thu 10/30/2014 15:48:58 : [ 27 91 81 1] ST 255 Thu 10/30/2014 15:50:07 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 13 01 LTOFFRR(01) Thu 10/30/2014 15:50:07 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Thu 10/30/2014 15:50:07 : [ 27 91 81 1] DOF 1 Thu 10/30/2014 15:50:07 : [ 27 91 81 1] ST 0 Thu 10/30/2014 15:50:07 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 13 01 LTOFFRR(01) Thu 10/30/2014 15:50:07 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Thu 10/30/2014 15:50:07 : [INST-DUP ] Previous message ignored. Thu 10/30/2014 15:50:07 : [INST-SRX ] 02 50 27.91.81 28.CB.3F 41 13 01 LTOFFRR(01) Thu 10/30/2014 15:50:07 : [Std-Cleanup ] 27.91.81-->ISY/PLM Group=1, Max Hops=1, Hops Left=0 Thu 10/30/2014 15:50:07 : [INST-DUP ] Previous message ignored. Thu 10/30/2014 15:50:07 : [INST-SRX ] 02 50 27.91.81 13.01.01 C7 06 00 (00) Thu 10/30/2014 15:50:07 : [Std-Group ] 27.91.81-->13.01.01, Max Hops=3, Hops Left=1 Thu 10/30/2014 15:50:07 : [INST-INFO ] Previous message ignored. Thu 10/30/2014 15:50:07 : [INST-SRX ] 02 50 27.91.81 13.01.01 CB 06 00 (00) Thu 10/30/2014 15:50:07 : [Std-Group ] 27.91.81-->13.01.01, Max Hops=3, Hops Left=2 Thu 10/30/2014 15:50:07 : [INST-INFO ] Previous message ignored.
  12. I'm curious, how did you clean up your system with that many nodes??
  13. I got it to work by unplugging and replugging the PLM ... should have thought of that sooner, but thanks for your suggestions I'll add them to my trial and error process next time something goes wrong!
  14. I feel like an idiot but that worked. I never reset the PLM before but now comms are working. Thanks so much, it's a huge relief!
  15. I checked the links on the plm and it has 36 devices, quite a few which are double and triple entries. status gives me the address, revision and connected. I couldn't add a motion sensor to the isy but it work on the insteon hub. =(
  16. So I think my isy994 is broken. From the admin panel I can log into the isy but none of my instead devices are communicating with the isy. Any time I try to enable/disable isy tells me communications fail. If I delete a device and try to add it, none of the devices show up in the add/update table. I thought that my devices might have all died but I connected to the insteon hub and it can control all the devices without any problems. Any ideas on how to trouble shoot? I did a power cycle on the isy as well ... I'm out of ideas and I don't know how long the warranty is?
  17. So I think my isy994 is broken. From the admin panel I can log into the isy but none of my instead devices are communicating with the isy. Any time I try to enable/disable isy tells me communications fail. If I delete a device and try to add it, none of the devices show up in the add/update table. I thought that my devices might have all died but I connected to the insteon hub and it can control all the devices without any problems. Any ideas on how to trouble shoot? I did a power cycle on the isy as well ... I'm out of ideas and I don't know how long the warranty is?
  18. Thanks guys, here's what my log says: Sat 10/11/2014 17:54:43 : [INST-TX-I1 ] 02 62 00 00 12 CF 13 00 Sat 10/11/2014 17:54:43 : [INST-ACK ] 02 62 00.00.12 CF 13 00 06 LTOFFRR(00) Sat 10/11/2014 18:01:44 : [ Time] 18:01:44 0(0) Sat 10/11/2014 18:04:22 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 11 01 LTONRR (01) Sat 10/11/2014 18:04:22 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:04:22 : [ 27 91 81 1] DON 1 Sat 10/11/2014 18:04:22 : [24 A BB 1 ] Link 2 : 0FE8 [A21228CB3FA51F01] Saving [..........A5....] Sat 10/11/2014 18:04:22 : [All ] Writing 1 bytes to devices Sat 10/11/2014 18:04:22 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 11 01 LTONRR (01) Sat 10/11/2014 18:04:22 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:04:22 : [INST-DUP ] Previous message ignored. Sat 10/11/2014 18:04:22 : [24 A BB 1 ] Link 2 : 0FE8 [A21228CB3FA51F01] Writing [..........A5....] Sat 10/11/2014 18:04:22 : [INST-TX-I2CS] 02 62 24 0A BB 1F 2F 00 00 02 0F EF 08 A2 12 28 CB 3F A5 1F 01 1E Sat 10/11/2014 18:04:22 : [INST-ACK ] 02 62 24.0A.BB 1F 2F 00 00 02 0F EF 08 A2 12 28 CB 3F A5 1F 01 1E 06 (00) Sat 10/11/2014 18:04:22 : [INST-TX-I1 ] 02 62 00 00 12 CF 11 00 Sat 10/11/2014 18:04:22 : [ 27 91 81 1] ST 255 Sat 10/11/2014 18:04:22 : [INST-ACK ] 02 62 00.00.12 CF 11 00 06 LTONRR (00) Sat 10/11/2014 18:04:22 : [Ext MH ] Unexpected Ack imCmd=62 cmd1=LTONRR 0x11 Sat 10/11/2014 18:04:24 : [INST-SRX ] 02 50 24.0A.BB 28.CB.3F 2B 2F 00 (00) Sat 10/11/2014 18:04:24 : [Std-Direct Ack] 24.0A.BB-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:04:27 : [INST-TX-I2CS] 02 62 24 0A BB 1F 2F 00 00 02 0F EF 08 A2 12 28 CB 3F A5 1F 01 1E Sat 10/11/2014 18:04:27 : [INST-ACK ] 02 62 24.0A.BB 1F 2F 00 00 02 0F EF 08 A2 12 28 CB 3F A5 1F 01 1E 06 (00) Sat 10/11/2014 18:04:28 : [INST-SRX ] 02 50 24.0A.BB 28.CB.3F 2B 2F 00 (00) Sat 10/11/2014 18:04:28 : [Std-Direct Ack] 24.0A.BB-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:05:56 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 13 01 LTOFFRR(01) Sat 10/11/2014 18:05:56 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:05:56 : [ 27 91 81 1] DOF 1 Sat 10/11/2014 18:05:56 : [ 27 91 81 1] ST 0 Sat 10/11/2014 18:05:57 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 13 01 LTOFFRR(01) Sat 10/11/2014 18:05:57 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:05:57 : [INST-DUP ] Previous message ignored. Sat 10/11/2014 18:05:57 : [INST-SRX ] 02 50 27.91.81 13.00.01 CB 06 00 (00) Sat 10/11/2014 18:05:57 : [Std-Group ] 27.91.81-->13.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:05:57 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 18:05:57 : [INST-SRX ] 02 50 27.91.81 13.00.01 CB 06 00 (00) Sat 10/11/2014 18:05:57 : [Std-Group ] 27.91.81-->13.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:05:57 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 18:08:56 : [INST-TX-I1 ] 02 62 00 00 12 CF 13 00 Sat 10/11/2014 18:08:56 : [INST-ACK ] 02 62 00.00.12 CF 13 00 06 LTOFFRR(00) Sat 10/11/2014 18:15:56 : [ Time] 18:15:57 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:17 0(0) Sat 10/11/2014 18:23:16 : [ Time] 18:23:18 0(0) Sat 10/11/2014 18:33:15 : [ Time] 18:33:17 0(0) Sat 10/11/2014 18:43:15 : [ Time] 18:43:17 0(0) Sat 10/11/2014 18:45:00 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 11 01 LTONRR (01) Sat 10/11/2014 18:45:00 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:45:00 : [ 27 91 81 1] DON 1 Sat 10/11/2014 18:45:00 : [ 27 91 81 1] ST 255 Sat 10/11/2014 18:45:00 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 11 01 LTONRR (01) Sat 10/11/2014 18:45:00 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:45:00 : [INST-DUP ] Previous message ignored. Sat 10/11/2014 18:45:00 : [INST-SRX ] 02 50 27.91.81 11.00.01 CB 06 00 (00) Sat 10/11/2014 18:45:00 : [Std-Group ] 27.91.81-->11.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:45:00 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 18:45:01 : [INST-SRX ] 02 50 24.0A.BB 11.00.01 CB 06 00 (00) Sat 10/11/2014 18:45:01 : [Std-Group ] 24.0A.BB-->11.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:45:01 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 18:45:01 : [INST-SRX ] 02 50 24.0A.BB 11.00.01 CB 06 00 (00) Sat 10/11/2014 18:45:01 : [Std-Group ] 24.0A.BB-->11.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:45:01 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 18:47:10 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 13 01 LTOFFRR(01) Sat 10/11/2014 18:47:10 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:47:10 : [ 27 91 81 1] DOF 1 Sat 10/11/2014 18:47:10 : [ 27 91 81 1] ST 0 Sat 10/11/2014 18:47:10 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 13 01 LTOFFRR(01) Sat 10/11/2014 18:47:10 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:47:10 : [INST-DUP ] Previous message ignored. Sat 10/11/2014 18:47:10 : [INST-SRX ] 02 50 27.91.81 13.00.01 CB 06 00 (00) Sat 10/11/2014 18:47:10 : [Std-Group ] 27.91.81-->13.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:47:10 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 18:47:10 : [INST-SRX ] 02 50 27.91.81 13.00.01 CB 06 00 (00) Sat 10/11/2014 18:47:10 : [Std-Group ] 27.91.81-->13.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:47:10 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 18:48:27 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 11 01 LTONRR (01) Sat 10/11/2014 18:48:27 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:48:27 : [ 27 91 81 1] DON 1 Sat 10/11/2014 18:48:27 : [ 27 91 81 1] ST 255 Sat 10/11/2014 18:48:27 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 11 01 LTONRR (01) Sat 10/11/2014 18:48:27 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:48:27 : [INST-DUP ] Previous message ignored. Sat 10/11/2014 18:48:27 : [INST-SRX ] 02 50 27.91.81 11.00.01 CB 06 00 (00) Sat 10/11/2014 18:48:27 : [Std-Group ] 27.91.81-->11.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:48:27 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 18:48:27 : [INST-SRX ] 02 50 27.91.81 11.00.01 CB 06 00 (00) Sat 10/11/2014 18:48:27 : [Std-Group ] 27.91.81-->11.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:48:27 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 18:49:27 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 13 01 LTOFFRR(01) Sat 10/11/2014 18:49:27 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:49:27 : [ 27 91 81 1] DOF 1 Sat 10/11/2014 18:49:27 : [ 27 91 81 1] ST 0 Sat 10/11/2014 18:49:27 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 13 01 LTOFFRR(01) Sat 10/11/2014 18:49:27 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:49:27 : [INST-DUP ] Previous message ignored. Sat 10/11/2014 18:49:27 : [INST-SRX ] 02 50 27.91.81 13.00.01 CB 06 00 (00) Sat 10/11/2014 18:49:27 : [Std-Group ] 27.91.81-->13.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:49:27 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 18:49:27 : [INST-SRX ] 02 50 27.91.81 13.00.01 CB 06 00 (00) Sat 10/11/2014 18:49:27 : [Std-Group ] 27.91.81-->13.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:49:27 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 18:50:04 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 11 01 LTONRR (01) Sat 10/11/2014 18:50:04 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:50:04 : [ 27 91 81 1] DON 1 Sat 10/11/2014 18:50:04 : [ 27 91 81 1] ST 255 Sat 10/11/2014 18:50:04 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 11 01 LTONRR (01) Sat 10/11/2014 18:50:04 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:50:04 : [INST-DUP ] Previous message ignored. Sat 10/11/2014 18:50:04 : [INST-SRX ] 02 50 27.91.81 11.00.01 CB 06 00 (00) Sat 10/11/2014 18:50:04 : [Std-Group ] 27.91.81-->11.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:50:04 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 18:50:05 : [INST-SRX ] 02 50 27.91.81 11.00.01 CB 06 00 (00) Sat 10/11/2014 18:50:05 : [Std-Group ] 27.91.81-->11.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:50:05 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 18:52:26 : [INST-TX-I1 ] 02 62 00 00 12 CF 13 00 Sat 10/11/2014 18:52:26 : [INST-ACK ] 02 62 00.00.12 CF 13 00 06 LTOFFRR(00) Sat 10/11/2014 18:52:35 : [INST-SRX ] 02 50 24.0A.BB 00.00.01 CB 11 00 LTONRR (00) Sat 10/11/2014 18:52:35 : [Std-Group ] 24.0A.BB-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:52:35 : [ 24 A BB 1] DON 0 Sat 10/11/2014 18:52:35 : [INST-SRX ] 02 50 24.0A.BB 00.00.01 CB 11 00 LTONRR (00) Sat 10/11/2014 18:52:35 : [Std-Group ] 24.0A.BB-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:52:35 : [INST-DUP ] Previous message ignored. Sat 10/11/2014 18:52:36 : [INST-SRX ] 02 50 24.0A.BB 11.00.01 CB 06 00 (00) Sat 10/11/2014 18:52:36 : [Std-Group ] 24.0A.BB-->11.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:52:36 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 18:52:36 : [INST-SRX ] 02 50 24.0A.BB 11.00.01 CB 06 00 (00) Sat 10/11/2014 18:52:36 : [Std-Group ] 24.0A.BB-->11.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:52:36 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 18:52:36 : [INST-TX-I1 ] 02 62 00 00 12 CF 11 00 Sat 10/11/2014 18:52:36 : [ 24 A BB 1] ST 255 Sat 10/11/2014 18:52:36 : [INST-ACK ] 02 62 00.00.12 CF 11 00 06 LTONRR (00) Sat 10/11/2014 18:52:36 : [ 24 A BB 1] ST 165 Sat 10/11/2014 18:57:14 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 13 01 LTOFFRR(01) Sat 10/11/2014 18:57:14 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:57:14 : [ 27 91 81 1] DOF 1 Sat 10/11/2014 18:57:14 : [ 27 91 81 1] ST 0 Sat 10/11/2014 18:57:15 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 13 01 LTOFFRR(01) Sat 10/11/2014 18:57:15 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:57:15 : [INST-DUP ] Previous message ignored. Sat 10/11/2014 18:57:15 : [INST-SRX ] 02 50 27.91.81 13.00.01 CB 06 00 (00) Sat 10/11/2014 18:57:15 : [Std-Group ] 27.91.81-->13.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:57:15 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 18:57:15 : [INST-SRX ] 02 50 27.91.81 13.00.01 CB 06 00 (00) Sat 10/11/2014 18:57:15 : [Std-Group ] 27.91.81-->13.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:57:15 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 18:59:31 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 11 01 LTONRR (01) Sat 10/11/2014 18:59:31 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:59:31 : [ 27 91 81 1] DON 1 Sat 10/11/2014 18:59:31 : [ 27 91 81 1] ST 255 Sat 10/11/2014 18:59:31 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 11 01 LTONRR (01) Sat 10/11/2014 18:59:31 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:59:31 : [INST-DUP ] Previous message ignored. Sat 10/11/2014 18:59:32 : [INST-SRX ] 02 50 27.91.81 11.00.01 CB 06 00 (00) Sat 10/11/2014 18:59:32 : [Std-Group ] 27.91.81-->11.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:59:32 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 18:59:32 : [INST-SRX ] 02 50 27.91.81 11.00.01 CB 06 00 (00) Sat 10/11/2014 18:59:32 : [Std-Group ] 27.91.81-->11.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 18:59:32 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 19:00:14 : [INST-TX-I1 ] 02 62 00 00 12 CF 13 00 Sat 10/11/2014 19:00:14 : [INST-ACK ] 02 62 00.00.12 CF 13 00 06 LTOFFRR(00) Sat 10/11/2014 19:00:14 : [ 24 A BB 1] ST 0 Sat 10/11/2014 19:00:19 : [INST-SRX ] 02 50 24.0A.BB 00.00.01 CB 11 00 LTONRR (00) Sat 10/11/2014 19:00:19 : [Std-Group ] 24.0A.BB-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 19:00:19 : [ 24 A BB 1] DON 0 Sat 10/11/2014 19:00:19 : [INST-SRX ] 02 50 24.0A.BB 00.00.01 CB 11 00 LTONRR (00) Sat 10/11/2014 19:00:19 : [Std-Group ] 24.0A.BB-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 19:00:19 : [INST-DUP ] Previous message ignored. Sat 10/11/2014 19:00:19 : [INST-SRX ] 02 50 24.0A.BB 11.00.01 CB 06 00 (00) Sat 10/11/2014 19:00:19 : [Std-Group ] 24.0A.BB-->11.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 19:00:19 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 19:00:19 : [INST-SRX ] 02 50 24.0A.BB 11.00.01 C7 06 00 (00) Sat 10/11/2014 19:00:19 : [Std-Group ] 24.0A.BB-->11.00.01, Max Hops=3, Hops Left=1 Sat 10/11/2014 19:00:19 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 19:00:20 : [INST-TX-I1 ] 02 62 00 00 12 CF 11 00 Sat 10/11/2014 19:00:20 : [INST-ACK ] 02 62 00.00.12 CF 11 00 06 LTONRR (00) Sat 10/11/2014 19:00:20 : [ 24 A BB 1] ST 255 Sat 10/11/2014 19:00:20 : [ 24 A BB 1] ST 165 Sat 10/11/2014 19:02:45 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 13 01 LTOFFRR(01) Sat 10/11/2014 19:02:45 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 19:02:45 : [ 27 91 81 1] DOF 1 Sat 10/11/2014 19:02:45 : [ 27 91 81 1] ST 0 Sat 10/11/2014 19:02:45 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 13 01 LTOFFRR(01) Sat 10/11/2014 19:02:45 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 19:02:45 : [INST-DUP ] Previous message ignored. Sat 10/11/2014 19:02:45 : [INST-SRX ] 02 50 27.91.81 13.00.01 CB 06 00 (00) Sat 10/11/2014 19:02:45 : [Std-Group ] 27.91.81-->13.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 19:02:45 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 19:02:45 : [INST-SRX ] 02 50 27.91.81 13.00.01 CB 06 00 (00) Sat 10/11/2014 19:02:45 : [Std-Group ] 27.91.81-->13.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 19:02:45 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 19:03:04 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 11 01 LTONRR (01) Sat 10/11/2014 19:03:04 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 19:03:04 : [ 27 91 81 1] DON 1 Sat 10/11/2014 19:03:04 : [ 27 91 81 1] ST 255 Sat 10/11/2014 19:03:04 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 11 01 LTONRR (01) Sat 10/11/2014 19:03:04 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 19:03:04 : [INST-DUP ] Previous message ignored. Sat 10/11/2014 19:03:04 : [INST-SRX ] 02 50 27.91.81 11.00.01 CB 06 00 (00) Sat 10/11/2014 19:03:04 : [Std-Group ] 27.91.81-->11.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 19:03:04 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 19:03:05 : [INST-SRX ] 02 50 27.91.81 11.00.01 CB 06 00 (00) Sat 10/11/2014 19:03:05 : [Std-Group ] 27.91.81-->11.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 19:03:05 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 19:04:19 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 13 01 LTOFFRR(01) Sat 10/11/2014 19:04:19 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 19:04:19 : [ 27 91 81 1] DOF 1 Sat 10/11/2014 19:04:19 : [ 27 91 81 1] ST 0 Sat 10/11/2014 19:04:19 : [INST-SRX ] 02 50 27.91.81 00.00.01 C7 13 01 LTOFFRR(01) Sat 10/11/2014 19:04:19 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=1 Sat 10/11/2014 19:04:19 : [INST-DUP ] Previous message ignored. Sat 10/11/2014 19:04:19 : [INST-SRX ] 02 50 27.91.81 13.00.01 CB 06 00 (00) Sat 10/11/2014 19:04:19 : [Std-Group ] 27.91.81-->13.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 19:04:19 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 19:04:19 : [INST-SRX ] 02 50 27.91.81 13.00.01 CB 06 00 (00) Sat 10/11/2014 19:04:19 : [Std-Group ] 27.91.81-->13.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 19:04:19 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 19:04:53 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 11 01 LTONRR (01) Sat 10/11/2014 19:04:53 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 19:04:53 : [ 27 91 81 1] DON 1 Sat 10/11/2014 19:04:53 : [ 27 91 81 1] ST 255 Sat 10/11/2014 19:04:53 : [INST-SRX ] 02 50 27.91.81 00.00.01 CB 11 01 LTONRR (01) Sat 10/11/2014 19:04:53 : [Std-Group ] 27.91.81-->Group=1, Max Hops=3, Hops Left=2 Sat 10/11/2014 19:04:53 : [INST-DUP ] Previous message ignored. Sat 10/11/2014 19:04:53 : [INST-SRX ] 02 50 27.91.81 11.00.01 CB 06 00 (00) Sat 10/11/2014 19:04:53 : [Std-Group ] 27.91.81-->11.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 19:04:53 : [INST-INFO ] Previous message ignored. Sat 10/11/2014 19:04:53 : [INST-SRX ] 02 50 27.91.81 11.00.01 CB 06 00 (00) Sat 10/11/2014 19:04:53 : [Std-Group ] 27.91.81-->11.00.01, Max Hops=3, Hops Left=2 Sat 10/11/2014 19:04:53 : [INST-INFO ] Previous message ignored.
  19. I don't have a delay written into the program if that's what you mean ... but if you mean how am I counting how long it takes to activate ... I'm using the Mississippi method?
  20. Thanks guys. I'm using insteon to insteon and it's a program written with conditions to change a scene that only has the light in it. In total I have 5 ms the furthest is maybe 35ft and closest maybe 15ft. How can I count the hops in the log? I'll try to paste it here. If that's the issue how can I reduce the hops or make it more efficient?
  21. That's pretty much it. I was wondering if a 3 second delay from motion sensor to lights on its natural? I watch the motion sensor and when the red light blinks I count to three. ..If I syst counting when I walk in the room it can be closer to 5 seconds. I'd this normal communication time?
  22. When it wasn't working it was inthe single digits and I replaced the battery twice. It works outside now, but i get false positives. Like I said, it's placed at the top of the awning facing down at the floor so someone passes through it to get to the door. i can't figure why I get all the false positives since I don't see anything passing through the beam unless it's really really wide ...?
  23. Thanks for taking the time to reply and sorry for my late reply even though I'm still having issues. The red light would not come on at all when outside but did when inside ... so I assumed it was just out of operating temps. Eventually it warmed up a little and started working .... sort of. I have it placed under an awning to the front door. It's on the top-inside so that it faces down directly to the floor. The flat/top of the motion sensor is facing the door and the bottom (which I believe angles downward to give more coverage) is facing the steps. I was getting a lot of false positives since I have email notification setup and have a camera viewing the door so i can check to see what "tripped" the sensor and 90% there was nothing visible and I can see to the sidewalk and half-way into the street so there were no cars passing by either even though I doubted that the range went that far. Today, I put a tape on the bottom half of the sensor "lens" to try to reduce the range to cover just the 4 x 2 space in front of the door but I ended up getting more false positives. Is there any good way to use this outdoors? Any rules or guides I should follow? The sensor is not on dusk/dawn mode, at least I don't think it is. And motion is not so much across as it is "into" the ir beam since the closed door doesn't allow for complete movement across .... should I try posting a pic???
  24. I just want to note that the ir beam doesn't have to go through the acrylic on the screen door, but my concern is that the beam is reflecting off of it and "screwing" something up. My purpose is for the sensor to recognize someone coming up to the door and initiating an insteon command to alert me that someone is at the door.
  25. I recently placed a motion sensor outside of the front entrance, approximately 3ft in front of the door underneath an awning but the sensor doesn't seem to register movement when I stand in front or wave my hands in front of the sensor. It works when indoors so I'm not sure the issue but I'll describe the setup. It's under an aluminum awning pointing towards a wooden door and in front of the door is a metal security door with see-through acrylic panels right behind it. I'm not sure if the transparent acrylic would create a problem or the 19F degree weather? Any suggestions?
