spiderbot
  1. Thanks for your response. I get the wrong data even if the *only* thing I do is query with https://.../rest/status. I *really* don't want to have to reprogram everything. I have a ton of home automation programs on the ISY.
  2. I have a 994i connected to about 15 devices in my home. I use MobiLink for my remote control. I can control everything. Here's the problem. * Start with all devices in off state. * I turn on a device remotely using the app. * I turn off the device manually. * I go to the app and it shows the light is still on. * If I 'cycle' the device off, everything works from there until the next manual action again goes out of sync. I have written a small app that saves off the results of a rest/status command over http. As above, it shows the device is on when it isn't. This is definitely an issue with the ISY. Any suggestions? Thanks
