Grant Baker
  1. OMG, that worked! Wiki and such says nothing about that procedure... Thanks! Grant
  2. no dice for either, "refused to connect"
  3. Brand new eisy is hardwired to local network and visible by router as eisy and responds to ping at the respective IP. However, clear cache and fresh start.jlp launch doesn’t find eisy. adding https://192.168.xxx:8443/desc though launcher says not found. I plugged in a monitor via hdmi, and it just shows a terminal. After admin/admin, it says “unless you’re a geek, you shouldn’t be here” 🤷🏻‍♂️ Edit: already 5 clicked power button to reboot network, and then 10 clicked power to factory reset. Same result. Edit 2: I'm on a macOS 12.6.3
