pizzdov
  1. FYI... Reflashing the EISY and restoring Backup worked great.
  2. Just to close this out... Michel has been helping out. Something has gotten corrupted and system needs to be reflashed. Thanks for the help!
  3. DennisC. To answer the power supply question... Been running it POE for months now so that it was using our network backed up power for stability. Switched back to a wall wart when I moved it into office for diagnostics with monitor. So, that did not help.
  4. Ok. Thanks for taking a look... This EISY acts as the core for hundreds of Insteon devices spread across three building at our ranch. Was hoping there was going to be something simple to reload system back on it so we could get back up quickly.
  5. I have an EISY that was working great and just stopped today. No power issues. Lost connection with portal. No longer shows active in router. It no longer responds to a ping. Does not register dhcp with router. Tried rebooting (5 button presses). No help. Tried shutdown (6 presses). Then restarting. No Help. Tried Factory Reset (10 presses). See NIC go dark then relight. No Help. Connected a monitor to HDMI port. See lots of kernel load info scroll by on power on. See warning in yellow... /var/polygot/.cache/pip not owned or not writable. See Pam_Start: System Errors. libopie.so.8 not found. At login prompt try typing admin. Throws more of the above errors. Then goes back to login prompt. Does not ask for password. Tried hitting button 10 times to again factory refresh EISY... Monitor shows a tpmcrb0:Incorrect Response Size:0 Then returns to above state Cannot connect to unit network-wise as it does not pull an IP. Any idea how to get this EISY back??? Thanks!
  6. I am in the same situation with several of the Keypads... Did you ever figure out how to reassign the button controlling the internal load in the i3 Keypad?
  7. Could not find anything in the forums... Has anyone looked at / tried integrating the EISY with the ArPi Open Security System Project? https://www.arpi-security.info/
  8. Thank you... I will give that a try. It is hard to tell from all the posts I find: Is the ISY running on the Polisy with USB PLM a stable incantation now? Is there a way to migrate the ISY-994i configuration to the Polisy ISY without having to start completely over; ie I have probably 100+ devices/switches/scenes/programs, etc?
  9. I have polisy unit that I have updated to 13... I have run sudo pkg update; sudo pkg upgrade; sudo service udx restart; sudo service isy restart. uname -a reports FreeBSD polisy 13.0-RELEASE-p4. udx is on 2.4.3.5. isy is on 5.0.4_36 service isy status => isy running as pid 1124. I was able to get the ISY Finder to see the ISY service at IP:8443/desc. I was able to get to the admin panel at IP:8443/desc. I tried to Restore a backup off my ISY994i with the admin panel at IP:8443/desc. It appeared to by cycling through the backup normally. I see now that it appears this is not a supported activity... Now, I can no longer connect to IP:8443/desc. ISY Finder does not fill in the Type/Version. Is there anyway to wipe the ISY configuration on the Polisy, so I can start over clean? Factory reset did not help. Found /var/isy directory on polisy which appears to have the configuration in FILES.... What can a remove? Thanks in advance
