Big Totoro
  1. Hello, I have ISY portal, everything is setup and working properly. Example: I can control all my lighting using "Ok Google, turn on all lights". and it turns on all the light in my house at once. What I want to do is use a Shortcut in the Google Home Assistant to say "Ok Google, Bedtime" and have it turn off all my lights in the house. The shortcuts in google home tell you "When I say... Bedtime" "Google assistant should do... ask isy(?) to turn off all lights" Any help as to how to properly word the shortcut to work? Thanks! James.
  2. Thanks. Ive sent them an email.
  3. Hello, I have a Google home device and wanted to use it to control my lighting etc. From what I could read, ISY portal is what I need to buy/subscribe to make that happen. My question is, I already own the Network Module, and I have Mobilinc Portal already. Do I need the ISY portal subscription on top of that? It also comes with the Network module as part of the package price, but I already own that, So am I paying for it again? thanks! Network Module Installed on: March 2, 2014 Active Climate Module Installed on: February 23, 2014 Active Portal Integration - MobiLinc Connect Installed on: January 25, 2014 Active
  4. Hello, I'm wondering if it's just me or is there never any light data reported by the weather stations? It's always reading 0%? There are a bunch of different stations near were I live but none of them seem to report that data. Help? Thanks!
  5. Hello, Thankyou. Adding that full line to the path section set everything on the alarm menu. I'm guessing that another resource script, but just turning everything off will set everything to off when I want to disarm it. So, that being said, any other commands, I should just track it with the network console and see what .cgi script calls out what string of variables, correct? Thanks again for your help. EDIT: The only error I get is a "TCP client read response failed" (Net Module Rule:1) when I run the tests. It also seems to lag the camera out as well, the WUI becomes very sluggish and freezes for a few seconds.
  6. Were do I put the "user=xxxxxxxx&pwd=xxxxxxxxx&next_url=alarm.htm&motion_armed=1&motion_sensitivity=0" etc. part? Do I put it as part of the path /set_alarm.cgi? box?
  7. Here is the source from the main page that has all the controls etc in the web interface Here is the source from the Alarm Configuration page of the Web interface. Here is The network capture when I select Motion Detection Armed checkbox (in the WUI), and hit submit: If there is anything more I can provide please let me know.
  8. Hello, I've been lurking around for about a month now reading everything I can read on this very new subject (to me). I have an ISY 994 and have purchased the Network Module. I also Have a Insteon Wireless IP camera. I have everything setup and working fine. My question is, I want to make an ISY program that triggers the IP camera's Alarm so that it will start trying to detect motion at certain times of the day. I can get the programming mostly done on my own, but the big problem I'm having is, I don't know how to use the resource manager very well in the network module. Furthermore, I can't figure out what the commands are, to send to the IP camera from the ISY program. I've used the network tracking console and it shows some cgi scripts being called out. get_params.cgi is always called, and it refers to an .htm file called alarm.htm. From here I can find one command called "motion_armed=0". this changes when I toggle the motion alarm setting on and off in the web interface. I'm totally lost as to how to get this information posted back to the ISY so it takes the change. I've used the post method in theresource manager and I get a long list back of settings in the test window, but nothing I do seems to change any of the values. I'd appreciate any help I can get. Thanks!
