Everything posted by clyford454
ISY won't connect to 2477S
Update. The above method did not work for the installed switch (found the switch but could not identify the engine) but did work for the second switch. FYI, Across 2 systems at 2 locations (100's of switches and devices) since the beginning of Insteon/ISY I have never had to do this. I started with X-10 in the 1980's.
Hello, I had a 2476ST go bad and replaced it with a 2477S. When trying to add a new insteon device the ISY Admin Console says "Cannot determine Insteon engine" It is a larger system and was in a remote building so I un-installed it and wired it into the plug next to the PLM. Same result. So I tried another new 2477S I had, in both places, same result. So, just for fun I tried a third new switch, 2477S, I had, this time only hardwired next to the PLM, still same result. The last switch in the test series was a 2477S Rev 7.0 My ISY is 5.3.4 My system has multiple other 2477S switches, never had an issue. Help.
Admin console freezes when left running
Hello Michel, "Just to make sure I understand the issue: Admin Console freezes IF AND ONLY IF your computer goes to sleep mode?" I believe this is the case. I was not aware the AC was not intended to be left open, I like it up for control from my PC. One slight improvement since the beginning, although I still have to re-start it, with the latest version I do not have to use Task Manager, the corner X works so it is a simple re-start. Thanks for the feedback.
Hello again, Now running current Admin console (4.2.2), no change, still locks up and has to be re-started after being unattended for a bit. PC is unattended frequently, disabling sleep is not a reasonable option.
Hello again. I cleared Java as suggested. I then try and start Admin Console through the dashboard and it is blocked by windows. "Publisher no recognized" I have a shortcut link I installed on my task bar that goes direct to the Admin Console (can't remember where I got it), if I click it, it re-down loads the same old 4.0.11 console and it runs fine. How to get to 4.2.2 is less than clear. Thanks.
Hello, I am new to the forum. I have searched for this problem but no luck finding a thread. Equipment and software: ISY 994i/Pro Firmware: 4.4.2.2 UI: v.4.0.11 Java: Version 7 Update 55 Windows 7 Home Premium, 64 bit Issue: If I leave the admin console running unattended it is usually frozen when I return. Is this caused by the PC sleeping? All of the buttons are gray and it will do nothing except shut down with the corner x. One note, I recently upgraded the firmware and Java, before that the problem was the same but then I had to actually force shut down with task manager, no controls worked in the admin console. Any help would be appreciated. No other issues, just tired of re-starting all the time.
