thtguy
Everything posted by thtguy
  1. The way I did mine was I bought an extra garage remote programmed it to work with the liftmaster and then I soldered my i o link onto that to trigger it. And with it being a remote you can basically put it anywhere as long as it's within range of the LiftMaster
  2. Came here specifically for this, was looking to add some i3 devices... guess it is time to upgrade to an eisy. I wish z-wave/zigbee were buit into the device rather than a USB dongle.
  3. Hey All, I searched these specific bulbs and didn't see any posts, so I thought I would check to see if anyone is using them and how they are working. I am primarily and Insteon guy, but with the discontinuation of the bulbs and I have had a few die, I am looking for replacements. I don't currenty have the ZWave module, I need to order it. I was looking into using polyglot and a hue hub, but don't won't to do all the extra hardware if I can find bulbs that work natively. https://inovelli.com/shop/z-wave-smart-bulbs/z-wave-rgbw-smart-bulb/#description Thanks,
  4. I have searched the forum and haven't found much relevant information so I will ask. With the discontinuation of the 2672-222 bulb, I wanted to see what everyone else has switched to? I want to stick with bulbs, possibly going to switch to some insteon outlets where I can but I have a few lamps that are plugged in, with other items that need to stay powered on. I was thinking of buying the ZWave module for my 994i pro, wanted to see if there were ZWave bulbs that people prefered?
  5. My apologies. I did just test the different speeds using voice control and it is working as expected. Thanks again,
  6. so how are you testing this? I can't change percentages for my fanlinc. In the Home App the fan icon has no controls available for manual intervention unlike all my lights and switiches. when I use Google Assistant it only shows me the fan as a on off switch (again no percentage dimmer space). seems this thread was hijacked. Do I just need to set my fanlinc as a light?
  7. In the Google home app on my phone it shows the fan icon. but in google assistant this is what it shows me.
  8. If I set my fanlinc as fan in the GH interface. It sees it as an on off switch, so not sure how anyone is able to set to different percentages. I just get On or off. But Google assistant will reply that they set the setting.
  9. In the portal I set the fanlinc device as a fan, but when I tell google to turn on the fan to hi, it says setting fan speed to high, but shows Fan (switch) On. It turns on to low. anone else see this issue?
