bwbeisne
  1. Good morning. Yes I rebooted twice. Once before doing anything to it. Once after clearing out unused programs and a few old devices. I have a few lamp modules that are only in use during the holidays. I removed them just try to clear all possible errors. What I am finding is that my Insteon network seems to be 100% solid. All device links and scenes work perfectly every time. Crisp and reliable. Anything that traverses the PLM is slow to respond (10s) OR doesn't respond at all.
  2. I have 4 or 5 scenes driven from various keypads. I have 6-8 keypads directly linked to various target devices. Lamps nearby etc..
  3. Thank you Geddy, No I am never leaving the admin console or the web server open. All automation is internal, either time or condition based within the ISY. The only external interface is the Alexa portal subscription which has worked fine for a very long time. As far as memory goes, the ISY shows 20mb used 868mb free. I don't know but I assume the Java memory usage statement pertains to the admin console only correct? For this everything is default and has been working fine using the defaults since I started with ISY 10+ years ago. I have never had to do anything other than 'get java' from day 1. Plus this issue appeared and persisted a month or two before I logged back in to the admin console. Yes, this is certainly starting to look like a hardware issue either SD card or PLM. Can we even buy PLMs any more? Are there any other, more useful logs of files I can share to help pinpoint this a little better?
  4. I do suspect it might be the PLM again but last time it just totally failed. It wasn't partial. Do you know the steps to clear out and fully reset the PLM?
  5. Hi guys. my ISY 994i has all of the sudden become very sluggish in controlling my devices. I occasionally get an error or two showing no comms with certain devices but a click within the admin console or the web UI usually wakes it back up and everything's fine. all of the sudden it takes four or five on clicks to get a device to turn on. this is intermittent. it only happens 50% of the time the other 50% of the time it's clean and crisp as it has been for the past 13 years. I do have backups of everything and I could do a full restore but I haven't had to touch my ISY in like 5 years. It just runs. Could one of you guide me resetting the PLM, the isy and the link table please? Below are some errors that I was seeing before cleaning up the programs and rebooting and then last is a error log of a clean boot. I did just renew my Alexa portal which had been expired only one day. The issues I am seeing started about a month previous. Thank you!! As found when I logged in. Sat 2025/08/02 04:58:59 AM System -170001 [UDSockets] PSub:41 error:6 Sat 2025/08/02 04:59:04 AM System -170001 [UDSockets] PSub:41 error:6 Sat 2025/08/02 04:59:09 AM System -170001 [UDSockets] PSub:41 error:6 Sat 2025/08/02 04:59:14 AM System -170001 [UDSockets] PSub:41 error:6 Sat 2025/08/02 04:59:19 AM System -170001 [UDSockets] PSub:41 error:6 Sat 2025/08/02 04:59:24 AM System -170001 [UDSockets] PSub:41 error:6 Sat 2025/08/02 04:59:29 AM System -170001 [UDSockets] PSub:41 error:6 Sat 2025/08/02 04:59:34 AM System -170001 [UDSockets] PSub:41 error:6 Sat 2025/08/02 04:59:39 AM System -170001 [UDSockets] PSub:41 error:6 Sat 2025/08/02 04:59:44 AM System -170001 [UDSockets] PSub:41 error:6 Sat 2025/08/02 04:59:49 AM System -170001 [UDSockets] PSub:41 error:6 Sat 2025/08/02 04:59:54 AM System -170001 [UDSockets] PSub:41 error:6 Sat 2025/08/02 04:59:59 AM System -170001 [UDSockets] PSub:41 error:6 Sat 2025/08/02 05:00:04 AM System -170001 [UDSockets] PSub:41 error:6 Sat 2025/08/02 05:00:09 AM System -170001 [UDSockets] PSub:41 error:6 Sat 2025/08/02 05:00:14 AM System -170001 [UDSockets] PSub:41 error:6 Sat 2025/08/02 05:00:19 AM System -170001 [UDSockets] PSub:41 error:6 Clean boot after clearing out old unused programs and a few devices: Mon 2026/01/19 01:00:00 AM System -10 n/a Mon 2026/01/19 07:29:29 AM System -10 n/a Tue 2026/01/20 03:01:54 AM System -10 n/a Tue 2026/01/20 08:01:38 AM System -170001 [Auth:-10104] 192.168.22.194:54719->80, Num=3 Tue 2026/01/20 08:01:38 AM System -170001 [Auth:-10104] 192.168.22.194:54720->80, Num=4 Tue 2026/01/20 08:01:45 AM System -170001 [Auth:-10104] 192.168.22.194:54730->80, Num=5 Tue 2026/01/20 08:22:34 AM System -10 n/a Tue 2026/01/20 08:48:38 AM System -5 Start Tue 2026/01/20 08:48:48 AM System -110022 /CONF/INSTENG.OPT Tue 2026/01/20 08:48:48 AM System -110012 /CONF/INSTENG.OPT Tue 2026/01/20 08:48:52 AM System -110022 /DEF/F6/I1/NLS/EN_US.TXT Tue 2026/01/20 08:48:53 AM System -110022 /CONF/UXT.BIN Tue 2026/01/20 08:48:53 AM System -110012 /CONF/UXT.BIN Tue 2026/01/20 08:48:55 AM System -170001 [Network] Established Tue 2026/01/20 08:48:55 AM System -60001 pool.ntp.org Tue 2026/01/20 08:48:55 AM System -140000 my.isy.io Tue 2026/01/20 08:48:55 AM System -60001 pool.ntp.org Tue 2026/01/20 08:51:10 AM System -10 n/a Tue 2026/01/20 08:52:17 AM System -10 n/a Tue 2026/01/20 09:05:47 AM System -10 n/a Tue 2026/01/20 09:19:04 AM System -5 Start Tue 2026/01/20 09:19:05 AM System -110022 /CONF/INSTENG.OPT Tue 2026/01/20 09:19:05 AM System -110012 /CONF/INSTENG.OPT Tue 2026/01/20 09:19:09 AM System -110022 /DEF/F6/I1/NLS/EN_US.TXT Tue 2026/01/20 09:19:10 AM System -110022 /CONF/UXT.BIN Tue 2026/01/20 09:19:10 AM System -110012 /CONF/UXT.BIN Tue 2026/01/20 09:19:11 AM System -170001 [Network] Established Tue 2026/01/20 09:19:12 AM System -60006 n/a Tue 2026/01/20 09:20:48 AM System -10 n/a
  6. Perfect!!! Thank you all so much!! Got it going. I only have to do minor cleanup on my other programs and scenes. The new firmware inserted a few odd things that wouldn't let the programs save. All is function well now!!
  7. Oh!! So hold down the set button and press 'write changes' in the console? OR long press set to put it in linking mode then write changes?
  8. Ok. I have successfully upgraded FW/UI to 5.3.3 and I am able to add the MS II correctly. The onboard temp sensor is a cool new feature. Lot's of possibilities there. I still cannot change the responder off time using the MS II options from the Admin Console. I suspect that the two 'time' related parameters are not for setting the time period to send an off command to the responder. I see 'Off Button Timeout' and 'Timeout' under motion. I have tried setting both and the MS II still turns off the responder in 30 seconds. My goal here is to set time period for sending the off signal to 20 minutes (1200s) instead of 30s. Is this not possible without buying an Insteon hub?
  9. Thank you guys! I knew I'd get good info here. Wow! V5 and up?? I need to do some reading and catch up before upgrading I think.
  10. Good morning ISY world. I am having a heck of a time getting a 2844-222 Motion II to work as I need. Directly linking to responder works fine BUT the default off timer is 30s. Way too short. Having no way to adjust off time with the 'set' button I decided to link it into my ISY. It looks to add correctly and I do see status but I get a ton of errors trying to set device params. Errors shown below in order UDI/FW: 4.9.0 ISY 994i 1. After clicking device options - Error - request failed 2. I hit OK and I can then see device options AND it even shows the values set from the previous attempt, 20min timeout and 'as motion is sensed' is checked. Is this stored in the admin console? 3. with all the above the actual sensor behavior is still stock at 30 seconds to off signal. It seems the sensor is not correctly represented in ISY. I have tried both 'auto detect' and manual selection of 2842-222, which is not exact but the only device listed. I have a 2844-222. Yes, I know I can create a program to handle this and I do use the ISY to handle my indoor motion sensors. I have many motion sensors of the old version and I don't want or need a program for each. I do, however need to set the 'OFF' time on all new motion sensors. Hopefully without buying an $80 Insteon hub to do so. Any ideas you guys might have would be awesome. Thank you
  11. Nice. I'll take a look at that. I saw a .pdf for all possible alexa/isyportal spoken commands. But no guidance for creating good spoken names Sent from my SM-N900V using Tapatalk
  12. Hi guys! Long time. Happy New Year!! I just finished bringing my ISY up to current with ISYportal and Alexa. Still using Mobi on the tablet as home base. I currently have Izzy/Alexa controlling devices, programs, variables and scenes. All works well except scenes. See below. In general here are a few things I've noted as odd, some ongoing questions and a general curiosity in others experiences with Alexa and Izzy. -Is it just me or is Alexa extra picky w/ scene spokens? Works well: entertainment, all lights, tv time Doesn't Work at all: entertain, everything, every thing, dusk -Why does alexa/izzy recognize a scene name enough to turn it on... And seconds later can't find the device to turn off? -Are there any fun spokens you guys are using that work well? None of these work well here. It was fun trying though. I wanna party, I want to party, Let's party all a no go with alexa. Runners up, turn on happy hour and we have guests. Pffft. no go. -Groups? Lighting scene and music macro? Has anyone had luck with an Alexa group or any other method of creating an Alexa macro? Set scene, play music -Setpoint control? Why can't I set my dimmable devices to an absolute setpoint? Set lamp to 75%... I can however dim or brighten all of my non relay devices? -Alexa looses her shit on a daily basis. Usually around dinnertime. Is this due to the 'primetime' load on the Amazon voice/cmd engine? It doesn't really seem to be the ambient noise level in the house. strange sounds, popping, screech, in responses and music basically not recognizing commands well during this time clears up after dinner. like clockwork. Even with the quirks Alexa/Izzy up and running is the coolest thing ever!!! Go UDI!!
  13. I just tried the shoebox method and got an 'ON'. Sweet. Thx. I don't remember what sensitivity is stored currently. Stay tuned... ))
  14. Hello. I have been focusing on many motion related tasks lately. I have some pretty nice functionality working for both the interior and exterior of my home. But... No matter what I try I cannot get a state change for Dusk/Dawn. Sensor config is full SW (jp5) Always sense is checked Light or dark. Here is what I know: (please correct me if I'm wrong here..) -Dusk/Dawn should = Off when bright -0 being darker, 128 being lighter -Takes 3-5 minutes to respond to light changes I have tried setting the threshold to reasonable and extreme limits on both the high and low side. I then placed the sensor under a bright light lamp for 10 minutes or so each time. Bright Environment w/ sensitivity set to 96 - no change Bright Environment w/ sensitivity set to 32 - no change Bright Environment w/ sensitivity set to 120 - no change Bright Environment w/ sensitivity set to 10 - no change I really want to trigger scenes with motion if it's cloudy or dim inside and I'm at a loss to get this status into the ISY. Any help would be greatly appreciated!!
  15. Ok. So a scene is a link or group of links then? One controller or trigger and one or many responders.
