btreinders
  1. Sorry, missed this reply. It was the data cable in the gateway. It was just a loosed connection, the connector was not plugged in completely. Yes I have seen the dump calibration too but the app will say it is doing a cal.
  2. Also, anyone else have issues this weekend with solar going to 0 and powerwall 3 saying it was 0% charged when I know it was not and other weirdness with 3rd party apps like Netzero and the PG3 plugin? I was afraid Tesla had changed the API again. I powered off both batteries and back up and it seems to have cured it for now.
  3. I just moved the Insteon dimmers I could where they would not flash and left the Keypadlincs for obvious reasons. They still flash if I am using the dimmer on A but I have not had any electronics die since the Powerwall 3s were installed in Dec 2024. It's not for a lack of electronics either. :) If there was a Keypadlinc alternative I'd replace those too but sadly there is not. At least not with 8 buttons for a reasonable price. Curiously I only see flashing when the Powerwall 3s are the only source, not when solar or the grid is powering the house. I did have a slow UD hub until I upgraded to the EISY from a Polisy. Sorry I am no help.
  4. Watching it boot with the top command and seeing it maxed out at 100%. UD support watched it boot up.
  5. Looks like UD made a fix for it. I created a ticket and they rolled out a new eisy-ui. 0.8.9 fixed it. It was also complicated by my Polisy being overworked. I uninstalled a few plugins that I could do without and things are much better.
  6. @Geddy Yes, I have a ton of devices and programs and I have to use 1024 to even get the AC to respond. I guess I can try 2048. I did contact support and they have me trying a new link to open the AC. It doesn't require portal username either. So far so good and they say it's a temp fix and will address the issue soon. I am on a wired connection and the PC is up 24/7 so I do leave it up and have never had any issues with that before. Hopefully I can continue to do that. Thanks!
  7. @Geddy Sometimes on startup but not always. It does always eventually happen if I leave it open and I have always left it open. If it didn't take so long to get into the program editing section I would close it. Even longer now that you have to enter your email as username. No, didn't notice this until now and the last update I did was Nov 27th. I guess I missed the issue when I did the update. Mine is a polisy and it says 6.0.3_1
  8. Since 6.0.3 I am getting a lot of socket timeout errors when the admin console is up and I also get one if I reboot the IoX from the admin console. Are other people seeing the same? Thank you!
  9. Is anyone else seeing issues with programs that are supposed to run at startup? I have one that executes as it should and does notify me that the IoX has finished rebooting but after that I make it wait 15 minutes before it starts executing most things. There is a 15 min wait and then it calls another program which sets a variable the allows execution. This worked fine until 6.0.3. Now it must be stopping in the 15 min wait somewhere. Thanks for any help.
  10. @Jimbo.Automates I added two new sensors to one thermostat and removed one from that thermostat and added it to another thermostat. The two new ones are under the correct thermostat and the old is also still under that thermostat as well and did not get changed to the other thermostat. I restarted the plugin and did a discover but that only added the two new ones. Any ideas? Thank you.
  11. btreinders replied to xKing's topic in Hue
    I deleted all the new ones. Installed 1.0.7 and the duplicates came back and this time they were the ones that worked. So all the scenes stopped working again. I installed 0.1.11 and the old ones were the ones working and the new ones did not. Good. So I deleted all the duplicates again and this time they did not come back but even after a re-discovery and a complete Polisy reboot they did not come back in the admin console. They do however still show up in the plugin nodes in PG3x. I can live with that until a fix comes around. Appreciate all the help!
  12. btreinders replied to xKing's topic in Hue
    @Bumbershoot Are you on 6.0.0? Did you have duplicates before with the HUE plugin 1.0.6? Thank you. I am tempted to delete the duplicates at this point since the old ones are now the ones working and then updating to 1.0.7. I think the extra 35 devices are causing networking issues since I am now getting TCP errors using them manually. Could just be 6.0.0 that caused that issue as well.
  13. btreinders replied to xKing's topic in Hue
    They are in the web interface called the EISY-UI if that's the web interface you mean. I reinstalled the 0.1.11 plugin and I still have the duplicates but the new ones are the ones not working now. Before it was the new ones that worked in programs, scenes and manually and not the old ones. This is a much better outcome for now until a fix can be provided. I will definitely purchase the new one once the issues are corrected. This was the first time I even looked at the EISY-UI. My programs cannot be seen. Just a list of them works. Clicking on one results in a reload button which if you select it you will be told the program does not exist. Does this not work yet? Thank you!
  14. btreinders replied to xKing's topic in Hue
    @xKing Thank you. Should I hold off changing all the programs and scenes until the duplicates are fixed? I don't want to have to do it all over twice. Can we go back to 0.1,11?
