joewb
Everything posted by joewb
  1. Michael, That did the trick!! Thank you very much. I guess the EZIO devices are picky about how they are linked. Now I dont have to lay in bed wondering if I remembered to shut the garage doors. Its amazing how much one relys on this stuff; once you have it, it is hard to go without. Joe
  2. Michael, The light does flicker when the doors open or close like the ezio is sending something out. What is the best way to factory reset the ezio? I have not been able to find that. And for adding it, I just used the start linking function, is there s specific way that you added yours? Thanks!! Joe
  3. My EZIO2x4 just failed so they sent me another one. I now have the same problem with the inputs not updating when my garage doors open or close. Is there a solution for this? I dont understand why my previous one worked flawlessly until an output relay failed?? I am running 2.7.0. Joe
  4. joewb replied to joewb's topic in ISY994
    Thank-you very much for the quick replys. I was sure that I was just doing something wrong. I feel much better now.
  5. joewb posted a topic in ISY994
    I have 1 KPL Version 1.65 and 2 Inline-linc dimmers. The KPL is a 6 Button. I have these in a home theater. I want to create scenes for watch tv, a movie, intermission and popcorn. I first linked these devices manually(tap-tap). I was able to control the Main load via the secondary buttons. I was having trouble setting on-levels and ramp rates so I bought the isy 99i pro. So I have it all communicating and I set up the scenes and the scenes work perfectly via the on and off buttons on the admin panel. Specifically the A and B buttons-TV and Movie. For the A button I dimm the front lights to 0 on a inline dimmer, the rear lights to 25% via an inline dimmer and I want the KPL load to dim to 0. I created the scenes putting in the responers first-including the KPL Main load as a responder, then last I put in Button A as the controller. When I turn on the main button it turns on all lights-just like when we will be going downstairs. Then when I turn on the A button only the front and rear lights dim, the main load stays on full bright. When I turn off the A button then the KPL switches to off and the main load dims down at the preset rate for the TV scene. Again, this scene works perfectly from the admin control panel for the isy on my pc. I tried factory resets, removing all devices and re-linking......I called Smarthome, they suggested I set the on level for the kpl main load at 2% (I had already tried this 3 times) but this time (the 4th) it works how I want it to, but on the KPL the main On button remains illuminated until I turn off the A or B buttons for the scene. Is this a bug? I am running v 2.65 on the isy 99pro-just got it 4 days ago. I have also messed with mutually exclusive buttons, that does not seem to change it either. Any ideas or is this just normal????
