jrd
  1. I have gotten an Amason Echo and have installed the ISY portal and that works,now I am trying to get my Molinc Pro working again through the ISY portal but it is not syncing with the isy portal. I thought I put the address and portal in correct.Any help appreciated.
  2. jrd replied to jrd's topic in ISY994
    Xathros that did thanks!
  3. jrd replied to jrd's topic in ISY994
    I updated to 4.2.3 still have no option for the zwave antenna ,what might I try?
  4. jrd replied to jrd's topic in ISY994
    I have 4.2.2 installed I will install 4.2.3, Thank you
  5. jrd posted a topic in ISY994
    Hello,I just purchased the zwave dongle and external antenna for my isy994i,I think I installed the antenna correctly but when I go into the isy admin console it doesn't show that you can pick internal or external antenna,have I not installed the external antenna correctly?
  6. Changing the X10 code worked,Thanks!
  7. I am having a problem and hope someone can help me please, I have a isy994i with a few x10 modules to control my outside lights. My carport light is set to A1 and when I trigger it ,it triggers my gates that uses a 74551 module. What could I do to keep this from happening?
  8. I am unable to get a new 2450 I/o to linc to my 994i with version 4.0.5 and plm 2413s what are the steps to do this? Also unable to linc with mobilinc.
