mjcumming
  1. I wonder why we just can use the extended command that can control the buttons directly.
  2. A prolonged hold did not reset the device
  3. probably not that long....will try again.
  4. I have tried - and from what I have read - that only resets the password not the entire system
  5. I cannot seem to find a way to "wipe" the ISY clean and start over...
  6. In addition, simple rest queries no longer work via HTTP. Rest queries using HTTPS work. As well, I am still able to connect to my ISY that is at my cabin with no problems.
  7. Hi, I added the ISY to the exception list. Using HTTPS from the launcher, I am able to login to the device but it fails when trying to Subscribe - Maximum Subscribers Reached.
  8. Yes, I have made sure that firmware and admin versions are the same.
  9. I have reverted back to .12 firmware and same problems. Tried restoring recent backups as well. Still same problems. I cannot get it back to a working situation.
  10. Windows 10, Java 8 updated to latest release. Firmware .16 and admin console .16. I see the option to debug subscriptions - where is the output? Getting all sorts of errors ie "Socket Open Failed" "XML Parse Error" I essentially cannot connect to the device. Tried several different PC's. Rebooted everything. Replaced the SD card in the ISY. ISY Finder locates the device, launches the Admin console. But now, I cannot even logon due to Socket Open Failed - Timeout messages.
  11. Upgraded from .12 to .16 and it has not gone well. The admin console is having problems connecting, and when it does its very slow, but it never gets fully connected as it give the "Maximum Subscribers Reached" message. Rebooting the ISY helps briefly but ultimately the connection is lost. Thoughts?
  12. The ISY will report changes it detects for any members of a scene and turns that scene "state" ON if any devices in that scene are ON. Agave & OpenHAB show this behavior and it is the ISY generating the state of a scene and publishing it via the REST interface. I am well aware of how the Insteon protocol works having programmed thousands of lines of code around it since the days of the PLC.
  13. Interestingly the REST interface generates scene ON/OFF events. If any light of a scene comes ON there is an ON event for that scene. If all devices are OFF then there is an OFF event for that scene.
  14. great, thank you. explains some unexpected behavior :)
