tesaurojm
  1. Yesterday I had a power failure in my home that lasted 20 minutes. Today I discovered I had an issue with ISY finder not being able to find my EISY. However, I was still able to access the ISY using UD Mobile and the ISY appeared to function normally performing daily routine programs. I took the following steps to try to get ISY Finder working. Cleared browser cache Cleared Java cache including all applications Linked u_d_.com to java security Rebooted computer and EISY Confirmed Computer and ISY both wired into same network None of the above steps worked so I tried using my laptop instead of my desktop and had the same results. At this point, I'm thinking that I would have to factory reset the EISY and load the backup file. I'm sure my issue was related to the power failure, and I was not a real fan of doing the reset so decided to take a break. After a while I decided to remove the power, Lan connection and PLM connection from the ISY and to unplug the PLM. After 30 seconds, I plugged everything back in and ISY Finder worked like a champ! Just thought I would share this information.
