dgmorr
  1. Thank you!
  2. Hey guys, I'm using a KPL 2487S to Button A to activate my pool pump program. When the program is complete Button A still stays lit. I tried adding another program to monitor the pool pump status and if on adjust backlight levels. Nothing I'm doing seems to be able to have the KPL button LEDS to keep updated. Does anyone have any advice on this? I've done quite a bit of searching and everything I'm finding is a lot more complicated than I'm trying to do. Thanks
  3. Hey guys, I have a failry simple Insteon setup so far and this will be my most 'complex' setup which I'm having some trouble with. I am using an ISY 994i with a 2475SDB and I/O Link 2450 for this circuit. I am basically trying to control my pool pump and millivolt pool heater. I have the 2475SDB wired in to the pool pump and have that working no problem. What I am trying to do is have the I/O Link 2450 control my pool heater's fireman switch (basically an open/close, no voltage). How do I link these two devices so that in any circumstance, the pool heater must be shut off 20 minutes prior to the pool pump shutting down. I'm a little lost on how to begin. My pump is 120V 20A if there was any question about that. Thanks.
