RocKKer
Everything posted by RocKKer
  1. Thanks for the info, it really helped! Seems to have sorted all my issues!
  2. eisy IoX 5.8.0 Zmatter USB I am using Minoston Z-Wave 800 Series Zwave Plug with Energy Monitoring. When I tested with one on the washing machine, it worked for a week or so (proof of concept), I then got a couple more for other appliance (Dishwasher and Microwave), both worked for a few days, now they're not updating the power usage and won't execute my simple programs, if energy usage is above/below a few watts, send message. The programs only execute when I manually force a query on those devices in the AC. I'd love to delete and start over with them but haven't come across a successful way to delete, they seem to take a bit of time to delete, maybe I'm not doing it right. I tried a couple ways but unplugging the device, remove failed, seems to work the best but sometimes the old device and a new incremented device shows in AC. Am I missing something?
  3. Yeah I should have known to do that! I see: 2/13/2023, 12:15:20 [pg3] info: IoX entry for Notification::2 OK 2/13/2023, 12:16:10 [pg3] info: [00:21:b9:02:5f:c0_2] Retrieved customparams 2/13/2023, 12:16:10 [pg3] info: [00:21:b9:02:5f:c0_2] Retrieved customparamsdoc 2/13/2023, 12:16:10 [pg3] info: [00:21:b9:02:5f:c0_2] Retrieved customtypedparams 2/13/2023, 12:16:10 [pg3] info: [00:21:b9:02:5f:c0_2] Retrieved customtypeddata 2/13/2023, 12:16:10 [pg3] info: [00:21:b9:02:5f:c0_2] Retrieved notices 2/13/2023, 12:16:10 [pg3] info: [00:21:b9:02:5f:c0_2] Retrieved oauth 2/13/2023, 12:17:52 [pg3] info: [00:21:b9:02:5f:c0_1] controller reporting command DOF 2/13/2023, 12:20:20 [pg3] info: Verifying node servers are installed on IoX correctly 2/13/2023, 12:20:20 [pg3] info: IoX entry for Ecobee::1 OK 2/13/2023, 12:20:20 [pg3] info: IoX entry for Notification::2 OK 2/13/2023, 12:20:27 [pg3] info: Caught SIGTERM/SIGINT Shutting down. 2/13/2023, 12:20:27 [pg3] info: Stopping running node servers... 2/13/2023, 12:20:27 [pg3] error: uncaughtException: write EPIPE Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:923:11) at Socket._write (node:net:935:8) at writeOrBuffer (node:internal/streams/writable:392:12) at _write (node:internal/streams/writable:333:10) at Writable.write (node:internal/streams/writable:337:10) at Console.log (/var/polyglot/node_modules/winston/lib/winston/transports/console.js:79:23) at Console._write (/var/polyglot/node_modules/winston-transport/index.js:103:17) at doWrite (/var/polyglot/node_modules/readable-stream/lib/_stream_writable.js:409:139) at writeOrBuffer (/var/polyglot/node_modules/readable-stream/lib/_stream_writable.js:398:5) at Writable.write (/var/polyglot/node_modules/readable-stream/lib/_stream_writable.js:307:11) at DerivedLogger.ondata (/var/polyglot/node_modules/readable-stream/lib/_stream_readable.js:681:20) at DerivedLogger.emit (node:events:525:35) at addChunk (/var/polyglot/node_modules/readable-stream/lib/_stream_readable.js:298:12) at readableAddChunk (/var/polyglot/node_modules/readable-stream/lib/_stream_readable.js:280:11) I can attach more log, if needed.
  4. NS shows up in AC, when I add Pushover keys I get the red exclamation! Am I doing something wrong?
  5. I have an Airscape (older model 3.5eWHF). I control it with network resources, does this NS offer me anything?
  6. I did get it figured out. I installed Polyglot on a RPi with the Magichome NS. I ordered and received an Magichome RGBW controller and it worked great for both controllers. Side note: I also moved the ISY and LED controllers to my IOT VLAN. The RPi, which I installed polyglot on, also runs PiHole and DNS, so it stays on the LAN. Once I got the firewall rules configured correctly for the ISY and LED controllers, it all works great!
  7. My understanding for WOL, you create the magic packet (using any port) on your source network, at the router you port forward, (changing the port to 9 UDP) to the broadcast address of the destination network. ie: for a 192.168.1.0 network, broadcast would be 192.168.1.255. I've used WOL, but never on a different VLAN (or subnets), so YMMV. You need to use a router that is not a consumer level router to implement VLANs. I doubt any Asus, Netgear, Linksys, TP-Link, etc. support VLANs. Pro-sumer type routers would (Ubiquiti, PfSense, OpnSense, etc.). I use PfSense and have an IOT VLAN working for my Ecobees and Amazon Echos. I will play around with this after I figure out LED strip lights.
  8. Thank you larryllix, I got it working with the NS. Works good enough for now while I figure out what I can control and how to implement. Another question: I want to eventually put these IOT devices (mostly the chinese controllers, not necessarily the ISY and NS) on a separate VLAN. While it's easiest to have all on the same VLAN, are there any suggestions on what devices should be where, I don't really want to create a mountain of firewall rules to keep all working.
  9. I have a rpi, I'll try the MH NS. Not sure I want to try the python3 method yet. Thank you for the offer and the info. I have a couple RGBW controllers coming, give them a try when they get here this weekend. I tried the NR strings you sent me, didn't change the color but I think the green gave a response back to ISY (some sort of characters in the NR resource response window), but I can't replicate.....
  10. I believe I'm using NR, (in the AC, I go to Configuration/Network Resources). Is that what the message means, ISY is expecting a response? That's ok if no response, the only response "I" require is that the lights change! I just reserved an IP, reset the RGB Controller and power cycled, it got the reserved IP. I made appropriate changes to the NR IP, still not controlling it. In theory, should the On/Off codes be the same between RGB and RGBW MagicHome controllers?
  11. ISY994i v5.0.16c Per the "Magic UFO Controller for RGBW" - I have one RGBW strip light and (I think) a MagicHome controller. I can connect the controller to my WiFI and control from the Android app MagicHome Pro, but can't control via ISY994i using NR. I know I ordered the wrong controller, I need an RGBW controller - but as a proof of concept I'm trying to use it for now. Using NR to send the device any command I get "TCP client read response failed - net module rule 8". Here is the controller and the NR configuration and the device IP is correct. I must be doing something wrong......
