jwarner964
  1. jwarner964 replied to jwarner964's topic in ISY994
    Hi Stu The PLM does not have a pass through outlet but I will try using a cord plugged into a outlet on the same circuit as the PLM Ill report back my out come thanks
  2. jwarner964 posted a topic in ISY994
    Hi All After more than 3 years my PLM failed, smarthome replaced it for free. I installed the new one, following the instructions in this forum. All went fine except I have one device that won't rewrite. its a switchlinc dimmer turning on some lights in my kitchen the switch is not connected to a load I've tried many times still not rewriting. what do I do next ? Thanks
  3. PLM
    Hi Thanks for the replies. I think I will get one to have on hand, it's good to know it only affects programs because I don't have any critical ones
  4. PLM
    Hi All Just a question about the life span of the plm. Mine is 2.5 yrs old works fine , should I be expecting to replace it soon and if so would it be wise to buy one and have it wait for this one to fail Thanks, Jeff
  5. jwarner964 replied to TheWabit's topic in ISY994
    The isy only changes every 2 degrees, the display changes every degree
  6. jwarner964 replied to TheWabit's topic in ISY994
    Hi My thermostat only up dates after 2 degrees, it won't change after each degree change
  7. Hi I do have one door sensor to turn a light on and off for a laundry room
  8. Hi Stu I don't know whats happening that why I posted my problem, was hoping someone could lead me in a direction to figure out how it is happening
  9. Hi All I have a outletlinc dimmer in a scene with a 6 button keypad button to turn on and off a lamp that works fine, I also have a stair light that has 2 switchlinc on/ off switches V.43. when you turn off the stair light using the switch at the top of the stairs, it is not the switch that feeds the load it turns off the outletlinc dimmer. but only after sunset. it will also turn it on. the status of the outlet dimmer does not change in the ISY. I do have some programs that run after sunset that include the outlet dimmer but the stair light switches are not in any programs. the switch that affects the outletlinc is pretty close to the outletlinc about 5 ft, everything has been working fine until lately can't seem to fix the problem, any help would be great, thanks
  10. Hi Stu I do have a program that sends me a text when the house drops below a certain temp, It gets cold here in MN and if I'm gone and the heat goes out it good to know.
  11. Hi Stu If I query it it will update to what the thermostat says
  12. Hi All I have installed a new thermostat, Insteon . the other one quit working the current temp doesn't seen to be updating to the ISY, the humidity does. the house is 72 the ISY shows 74 I think I remember that it doesn't update every degree but how often should it Thanks
  13. Hi It looks like to me that the power is in the light box and the cable coming from the light is a switch loop
  14. Hi I like to use more than 1 program, If 6 pm then set xxx to 100 % Program 2 If 8pm Then set xxx to 50 % Ect.
  15. Hi You should always link your devices in the isy, not manually. The isy would not know those links
