tallngro
Everything posted by tallngro
  1. I did a quick search on the forum and couldn't find someone that has a similar scenario to use the FanLinc on one button. I have been running this for about a week now. It's been working nicely. I have a scene named "Fan", with the FanLinc and non toggle KPL button for status purposes. I also use a RemoteLinc in the room to control the fan in similar fashion. The KPL button is "MB_B Fan Control". The RemoteLinc button is "MB_RMC". If there is some code can be cleaned up, please don't hesitate to suggest. The programs are as follows: Click to High: If Status 'Second Level / Devices / Master Bedroom / MasterBed Fan' is Off And-( | Control 'Second Level / Devices / Master Bedroom / MB_RMC - Fan' is switched On | Or Control 'Second Level / Devices / Master Bedroom / MB_B Fan Control' is switched On -) Or-( | Status 'Second Level / Devices / Master Bedroom / MasterBed Fan' is Low | And Control 'Second Level / Devices / Master Bedroom / MB_RMC - Fan' is switched On -) Then Set Scene 'Second Level / Scenes / Fan' On Else - No Actions - (To add one, press 'Action') Click to Medium: If Status 'Second Level / Devices / Master Bedroom / MasterBed Fan' is High And-( | Control 'Second Level / Devices / Master Bedroom / MB_RMC - Fan' is switched On | Or Control 'Second Level / Devices / Master Bedroom / MB_B Fan Control' is switched On -) Then Set 'Second Level / Devices / Master Bedroom / MasterBed Fan' Med Else - No Actions - (To add one, press 'Action') Click to Low: If Status 'Second Level / Devices / Master Bedroom / MasterBed Fan' is Med And-( | Control 'Second Level / Devices / Master Bedroom / MB_RMC - Fan' is switched On | Or Control 'Second Level / Devices / Master Bedroom / MB_B Fan Control' is switched On -) Then Set 'Second Level / Devices / Master Bedroom / MasterBed Fan' Low Else - No Actions - (To add one, press 'Action') Click to Off: If Control 'Second Level / Devices / Master Bedroom / MB_RMC - Fan' is switched Off Or-( | Status 'Second Level / Devices / Master Bedroom / MasterBed Fan' is Low | And Control 'Second Level / Devices / Master Bedroom / MB_B Fan Control' is switched On -) Then Set Scene 'Second Level / Scenes / Fan' Off Else - No Actions - (To add one, press 'Action')
  2. I was overcomplicating it. I knew it would something simple. It makes a ton of sense now. Thanks a lot Xathros
  3. I have just started to setup my home with isy/insteon. I have been unable to figure out one issue and wanted to see if anyone knew if it was even possible. I am trying to setup a scene where On/Off turns on all scenes and shows the status of the scene via LED on the KPL. Example of my setup below. 6 KPL: On/Off - No load (controls scenes through software) Scene A - Living Room Scene B - None Scene C - Dining Room Scene D - Kitchen My attempts: 1. I made the On/Off control all scenes by creating a scene with all the separate units (micro dimmers, lamplincs) as responders and the On/Off as controller. However this doesn't show status of the scenes on LED. 2. I created a scene with On/Off as controller and scenes A,C,D as responders. The LEDs light up, but the scenes do not activate. 3. I created a program "If On/Off is switched on, then set scene A on and C and D…". This works, but is there a way to get the scenes to activate simultaneously? This program turns each scene on chronologically. I figure I'd ask. If it's impossible to do this, I'll just go with my 1st attempt and live with the LED status off. Thanks in advance.
