pwerboost
  1. pwerboost replied to pwerboost's topic in ISY994
    Thank you guys!
  2. pwerboost replied to pwerboost's topic in ISY994
    Thank you for the explanation sir, one last question. It would matter if i put Repeat 4 time at the end or it has to say Repeat 1 time, i just wonder what would happen.
  3. pwerboost replied to pwerboost's topic in ISY994
    The only place where i have to add the "Repeat command" is at the end and none at the beginning?
  4. pwerboost posted a topic in ISY994
    Hi guys. i need help with a program basically i need a program for my irrigation system. The program needs to open a shut off valve first then start zone 1 for 5 min then move to next zone, total 5 zones, then repeat the whole process 4 times and after the Repeat command is completed, i need to close the shutoff valve. I can get almost everything to work but i don't know how to execute an order only when the Repeat cycle is completed. Thanks
  5. i did deleted the applet as well and i had to download a fresh one and re-install. well, i restored the devices and still no working.
  6. i had cleared the java cache 3 times using "java deleting everything" with no luck. i guess the only option now is to use Restore Device.
  7. hi, i upgraded Java 8 two days ago and everything seems to be ok. Today, i installed two micro switch modules and to my surprise i can not get them to work using scenes commands. they work if i trigger them using the admin on and off feature on devices but when i make a scene and i include an action command to turn on or off nothing happens. This is the event viewer level 3 when i send the command from devices (works fine) Thu 01/21/2016 06:44:54 PM : [iNST-TX-I1 ] 02 62 32 A8 88 0F 11 FF Thu 01/21/2016 06:44:54 PM : [iNST-ACK ] 02 62 32.A8.88 0F 11 FF 06 LTONRR (FF) Thu 01/21/2016 06:44:55 PM : [iNST-SRX ] 02 50 32.A8.88 3B.97.4B 2F 11 FF LTONRR (FF) Thu 01/21/2016 06:44:55 PM : [std-Direct Ack] 32.A8.88-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Thu 01/21/2016 06:44:55 PM : [D2D EVENT ] Event [32 A8 88 1] [sT] [255] uom=0 prec=-1 Thu 01/21/2016 06:44:55 PM : [ 32 A8 88 1] ST 255 ​and this is the event viewer level 3 when i force the module to turn on using the scenes command (nothing happens) Thu 01/21/2016 06:45:43 PM : [ Time] 18:45:45 14(0) anybody has any idea what is going on? i already clear the Java cache and reinstalled the isy admin applet but it still not working . FYI: i am using firmware and UI version v.4.3.26
  8. yes, i always put them into linking mode to write updates. i have a little over 100 insteon devices across the house which probably 30 of them are dual band, i also have 4 range extenders, filterlinc on the fridge, microwave, etc and i even installed a phase coupler hardwired. The micro modules doesn't show the 1011 symbol and they drive all LED light bulbs and fluorescent bulbs only in the garage and main bathroom.
  9. i did put the motion sensors into linking mode and after restoring i pushed the back button twice to get it out the linking mode before i moved to the next sensor.
  10. All my motion sensors are showing the 1011 on the UI and restored them already more than once.
  11. but the micro switch that control the light attach to the motion sensor actually miss a lot of times to the point that i have to just turn the lights manually. this issue is happening all across the house since i replaced the PLM before that it was just random lights turning on by itself or other not responding at all.
  12. i did the event viewer level 3 and i chose one of the motion sensors that blinks rapidly after is triggered. (2D.3F.EA) Mon 01/04/2016 01:30:33 PM : [iNST-SRX ] 02 50 2D.3F.EA 00.00.01 CF 11 01 LTONRR (01) Mon 01/04/2016 01:30:33 PM : [std-Group ] 2D.3F.EA-->Group=1, Max Hops=3, Hops Left=3 Mon 01/04/2016 01:30:33 PM : [D2D EVENT ] Event [2D 3F EA 1] [DON] [1] uom=0 prec=-1 Mon 01/04/2016 01:30:33 PM : [ 2D 3F EA 1] DON 1 Mon 01/04/2016 01:30:33 PM : [D2D EVENT ] Event [2D 3F EA 1] [sT] [255] uom=0 prec=-1 Mon 01/04/2016 01:30:33 PM : [ 2D 3F EA 1] ST 255 Mon 01/04/2016 01:30:33 PM : [D2D-CMP 0037] STS [2D 3F EA 1] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> true Mon 01/04/2016 01:30:33 PM : [ Time] 13:30:33 13(0) Mon 01/04/2016 01:30:33 PM : [iNST-TX-I1 ] 02 62 2B 16 03 0F 12 00 Mon 01/04/2016 01:30:33 PM : [iNST-ACK ] 02 62 2B.16.03 0F 12 00 06 LTON-F (00) Mon 01/04/2016 01:30:33 PM : [iNST-ACK ] 02 62 2B.16.03 0F 12 00 06 LTON-F (00): Duplicate or ACK for a different device Mon 01/04/2016 01:30:33 PM : [iNST-SRX ] 02 50 2D.3F.EA 00.00.01 CB 11 01 LTONRR (01) Mon 01/04/2016 01:30:33 PM : [std-Group ] 2D.3F.EA-->Group=1, Max Hops=3, Hops Left=2 Mon 01/04/2016 01:30:33 PM : [iNST-DUP ] Previous message ignored. Mon 01/04/2016 01:30:34 PM : [iNST-SRX ] 02 50 2B.16.03 3B.97.4B 2B 12 00 LTON-F (00) Mon 01/04/2016 01:30:34 PM : [std-Direct Ack] 2B.16.03-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 01/04/2016 01:30:34 PM : [D2D EVENT ] Event [2B 16 3 1] [sT] [255] uom=0 prec=-1 Mon 01/04/2016 01:30:34 PM : [ 2B 16 3 1] ST 255 Mon 01/04/2016 01:30:56 PM : [iNST-SRX ] 02 50 27.72.93 13.02.01 CB 06 02 (02) Mon 01/04/2016 01:30:56 PM : [std-Group ] 27.72.93-->13.02.01, Max Hops=3, Hops Left=2 Mon 01/04/2016 01:30:56 PM : [iNST-INFO ] Previous message ignored. Mon 01/04/2016 01:30:57 PM : [iNST-SRX ] 02 50 27.72.93 13.02.01 CF 06 02 (02) Mon 01/04/2016 01:30:57 PM : [std-Group ] 27.72.93-->13.02.01, Max Hops=3, Hops Left=3 Mon 01/04/2016 01:30:57 PM : [iNST-INFO ] Previous message ignored. Mon 01/04/2016 01:31:00 PM : [iNST-SRX ] 02 50 2D.3F.EA 11.01.01 CF 06 01 (01) Mon 01/04/2016 01:31:00 PM : [std-Group ] 2D.3F.EA-->11.01.01, Max Hops=3, Hops Left=3 Mon 01/04/2016 01:31:00 PM : [iNST-INFO ] Previous message ignored. Mon 01/04/2016 01:31:01 PM : [iNST-SRX ] 02 50 2D.3F.EA 11.01.01 CF 06 01 (01) Mon 01/04/2016 01:31:01 PM : [std-Group ] 2D.3F.EA-->11.01.01, Max Hops=3, Hops Left=3 Mon 01/04/2016 01:31:01 PM : [iNST-INFO ] Previous message ignored. Mon 01/04/2016 01:31:30 PM : [iNST-SRX ] 02 50 2D.3F.EA 00.00.01 CF 13 01 LTOFFRR(01) Mon 01/04/2016 01:31:30 PM : [std-Group ] 2D.3F.EA-->Group=1, Max Hops=3, Hops Left=3 Mon 01/04/2016 01:31:30 PM : [D2D EVENT ] Event [2D 3F EA 1] [DOF] [1] uom=0 prec=-1 Mon 01/04/2016 01:31:30 PM : [ 2D 3F EA 1] DOF 1 Mon 01/04/2016 01:31:30 PM : [D2D EVENT ] Event [2D 3F EA 1] [sT] [0] uom=0 prec=-1 Mon 01/04/2016 01:31:30 PM : [ 2D 3F EA 1] ST 0 Mon 01/04/2016 01:31:30 PM : [D2D-CMP 0037] STS [2D 3F EA 1] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false Mon 01/04/2016 01:31:30 PM : [iNST-SRX ] 02 50 2D.3F.EA 00.00.01 CF 13 01 LTOFFRR(01) Mon 01/04/2016 01:31:30 PM : [std-Group ] 2D.3F.EA-->Group=1, Max Hops=3, Hops Left=3 Mon 01/04/2016 01:31:30 PM : [iNST-DUP ] Previous message ignored. Mon 01/04/2016 01:31:33 PM : [ Time] 13:31:33 13(0) Mon 01/04/2016 01:31:33 PM : [iNST-TX-I1 ] 02 62 2B 16 03 0F 13 00 Mon 01/04/2016 01:31:33 PM : [iNST-ACK ] 02 62 2B.16.03 0F 13 00 06 LTOFFRR(00) Mon 01/04/2016 01:31:33 PM : [iNST-ACK ] 02 62 2B.16.03 0F 13 00 06 LTOFFRR(00): Duplicate or ACK for a different device Mon 01/04/2016 01:31:35 PM : [iNST-SRX ] 02 50 2B.16.03 3B.97.4B 2B 13 00 LTOFFRR(00) Mon 01/04/2016 01:31:35 PM : [std-Direct Ack] 2B.16.03-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Mon 01/04/2016 01:31:35 PM : [D2D EVENT ] Event [2B 16 3 1] [sT] [0] uom=0 prec=-1 Mon 01/04/2016 01:31:35 PM : [ 2B 16 3 1] ST 0 Mon 01/04/2016 01:31:35 PM : [iNST-SRX ] 02 50 2B.16.03 3B.97.4B 23 13 00 LTOFFRR(00) Mon 01/04/2016 01:31:35 PM : [std-Direct Ack] 2B.16.03-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Mon 01/04/2016 01:31:35 PM : [iNST-DUP ] Previous message ignored. Mon 01/04/2016 01:31:57 PM : [iNST-SRX ] 02 50 2D.3F.EA 13.01.01 CF 06 01 (01) Mon 01/04/2016 01:31:57 PM : [std-Group ] 2D.3F.EA-->13.01.01, Max Hops=3, Hops Left=3 Mon 01/04/2016 01:31:57 PM : [iNST-INFO ] Previous message ignored. Mon 01/04/2016 01:31:58 PM : [iNST-SRX ] 02 50 2D.3F.EA 13.01.01 CB 06 01 (01) Mon 01/04/2016 01:31:58 PM : [std-Group ] 2D.3F.EA-->13.01.01, Max Hops=3, Hops Left=2 Mon 01/04/2016 01:31:58 PM : [iNST-INFO ] Previous message ignored. END
  13. sorry for the stupid question but what do you mean with level 3? PLM info/status?
  14. I would like to know how to diagnose the origin of my problem. all my motion sensors flash the LED a random times, most of them right after are triggered. my micro switches doesn't turn the lights off when they are supposed to. (most are based on timers not on motion sensors) I suspected it was my two years old PLM because i always had all kind of random issues for long time but they were not too bad, i lived with them. but now that i bought a brand new PLM everything is worse. Can i erase the PLM and all the links and scenes and start all over again? at this point after all the time and money i'd spent buying filters, bridges and repeaters, i wouldn't mind if it solve the problems for good. Thanks.
