mdarcy
Everything posted by mdarcy
  1. I replaced 3 of my Insteon thermostats that have controlled my zone heating for many years. They were beginning to fail, so I decided to replace them with Meross MTS300 matter enabled thermostats which are a very cost effective solution. I have been very happy with the performance of them thus far. I added them to the Meross app and configured them all. I then tried to add them to the UD Mobile app without success. After reading some of the forums, I decided to follow the suggestions and add them to Apple Home app first and then to the UD mobile app. I was able to add all three of them to the UD Mobile app using the multi-admin capabilities by generating a code in Apple Home and was able to successfully add them and manipulate them in UD Mobile. I then checked to see if I could see them in the eISY UI. I could see each thermostat. That was a few days ago. I noticed today that one of the thermostats on the UD Mobile interface shows blanks for all of the values. eISY also shows one of the devices with an "exclamation point" and no values. I can still see them in Apple Home and in the Meross app and responding properly. My question is what is the proper steps to solve this? Can I just delete the thermostat from eISY and UD Mobile and re-add it? Do I have to clear a cache or other marker in the software that will prevent it from adding again? I know the universal devices matter is still beta, so I want make sure I do things right and don't lock my devices out of this environment. Any suggestions?
  2. I have been testing my programs after a recent migration from an ISY944I to an EISY. I noticed all of my leak sensors (wet), on the Summary tab under Programs, have an Activity = '-Not Loaded' and a Status = 'Out of Memory'. I checked each program and I don't see anything flagged or anything unusual. Any ideas?
  3. Thank you! This helps. I would like to document a couple of things as I am using the OpenWeatherMap from the Node store to get this running again. 1. I was choosing the wrong ELK device in the drop down. I needed to select the one marked "Area 1" instead of the keypads I was choosing. 2. I had to also tweak the configuration message I had when I had this running and configured in my ISY944i before they shut down the PolyGlot cloud. You can find this in CONFIGURATION>EMAIL/NOTIFICATIONS>CUSTOMIZATIONS. I had to change my substitution variable on my ELK Out Temp customization to: ${sys.node.n001_controller.CLITEMP}. You can find your node name in the UI: Go to the node on the left side pane and select it. Under the title OpenWeatherMap there is white lettering with the name of the node. The name of this node is n001_controller.
  4. Recently upgraded to EISY. I had a program on m ISY that used to poll weather data and display the outside temperature on my ELK keypads. The migration from my ISY to EISY wiped that program out. I have installed the ELK node server and have been trying to recreate the program, but without the old program. I thought I had found a couple of early posts, but they don't really match up with what is in the Elk interface now. Does anybody have this working on the EISY with the ELK node server that could share?
  5. I did figure it out. I thought I chose a 'slot' when installing the Elk node. I did not. I chose the next open slot during the install process and it appeared on my Dashboard.
  6. New to eisy and just 'migrated' my ISY944i yesterday. I am trying to get the ELKM1 integration working as I use it for my mobile clients I purchased the ELK integration from the Node Server Store. Purchase was successful, as it showed up under my purchases tab. I checked my dashboard and did not see it on my ISY dashboard. I checked the log and did not see any reference to that node being started or errros for the node. I tried to (Re)Install from the purchases screen, but no luck. Am I missing a step to get this node started? I did the same thing with OpenWeatherMap and it worked just fine. I was able to configure and get info to populate in the ISY on my new EISY with weather info. Here is a screen shot of my dashboard. I expected to see an ELK node too. Am I missing a step?
  7. mdarcy posted a topic in eisy
    I just got my eisy and have been trying to get it ready to restore from my isy. I have read the WIKI and read the forum posts. Thanks to all who provided this information. I got to learn from your issues and experiences. I do have a couple of questions, though. Per the WIKI, I wanted to get the eisy updated before restoring my isy backup. I tried to UPGRADE PACKAGES button. The UI kept telling me the "eisy was in the middle of an upgrade" for almost 24 hours. I found another thread that said to look a the log. I used PuTTY to SSH into the eISY and looked at the log. It seemed to be waiting on something(??!). Somebody suggested to kick off an upgrade with the single button press (1 press). I tried that and nothing happened. I tried the multi-function reboot (5 presses), nothing. I tried the multi-button shutdown ( 5 presses), nothing. Then I tried getting into the UI and tried Configuration/Reboot, nothing. I finally unplugged the device and waited 5 minutes and plugged back in, cleared my Java cache and launched a UI session. The session told me I needed to reboot. This time, I used the REBOOT button under Configuration and it rebooted. I am at 5.6.0 for both firmware and UI and it seems to be working. Is 5.6.0 the right Firmware/UI level? What am I doing wrong? Is there a trick to the multi function button presses? There doesn't seem to be any confirmation that the eisy 'accepted' the command is processing it. Is there something that would show a reboot/shutdown/upgrade progress? Do you have to rely on an SSH session? Once I understand how this works, I will feel more comfortable with this process.
