BryanLee
Everything posted by BryanLee
  1. I would like to use one button on a SwitchLinc to control a FanLinc's speeds. My thoughts are this: Pressing the button turns the fan on low, and beeps the SwitchLinc once, it also sets a five second countdown. Pressing the button again within this five second countdown cycles through Medium (2 beeps), High (3 Beeps) Off. Each button press resets the countdown timer to five seconds. If the button is pressed after the five second countdown, it sets the fan to off. I've been doing some searches but am still scratching my head. Can anyone give me some pointers?
  2. Thank you. I think I got the desired effect. But just to clarify, for my own education and others after... I think you gave me two different solutions. First solution On the "Main" tab, select the button in the left pane, on the right side, select "Buttons Toggle Mode" , select the button again and select "Toggle On/Off", then select "on" for "Non-Toggle-on". From my understanding this will trigger any programs that use "control is switched on", but it won't make the on state persistent. I also removed the "Set 'Hallway Switch - Goodnight' On 0 / Off 0 (Backlight Level)" line from my program, as with the toggle mode set, the LED light never turns on. Second solution The other solutions would have been to leave the toggle mode as it was, but change the final line of my program to activate a scene that sets the button to zero. This will allow the button LED to be lit while the "fade out" is happening, and then turn it off. I choose the first solution.
  3. I have a goodnight program. This program is to turn a hallway light on to 30% (via a scene), and then turn various lights off (again, via a scene). Part of this second scene is also to slowly turn off the hallway light over 19 seconds. Then turn the "Goodnight button's" LED off. Goodnight Scene - WalkingToBed Hallway Switch: On Level 30, Ramp Rate 27 (2 seconds) Goodnight Scene Various lights: On Level 0, Ramp Rate 31 (0.1 seconds) Hallway Switch: On Level: 0, Ramp Rate 23 (19 seconds) Program Goodnight: if control 'Hallway Switch - Goodnight' is switched On And control 'Hallway Switch - Goodnight' is not switched Off Then Set Scene 'Goodnight-walking" On Wait 3 seconds Set Scene 'Goodnight' On Wait 25 seconds Set 'Hallway Switch - Goodnight' On 0 / Off 0 (Backlight Level) Else - No Actions This has almost the desired effect. When I press button H (Hallway Switch - Goodnight), the hallway light ramps to 30% over two seconds, the rest of the lights quickly fade in .1 second. Then the hallway light fades off over 19 seconds, and finally the LED behind "Hallway Swtich - Goodnight" turns off. The only problem... the next time I go to use the "Goodnight scene" the first button press does nothing, and the second press activates the program. It's as if the button believes it's still in the "on" condition, despite the fact that I turned it off via the program. I'm sure it's something simple I'm missing. Thank you.
  4. Factory reset and restore device worked. Thanks guys. Full solution here, for anyone who finds this thread via search later: [*:1zs93xkt] Pull out the set button on the bottom of the KeypadLinc. Use a small flat head screwdriver. Be careful, but it does take a little more force than I expected. It pulls out approximately 1/8" "snaps" into position, and will hold that position. This creates an "Air Gap." [*:1zs93xkt] Wait at least ten seconds [*:1zs93xkt] Press the set button back in and hold it down [*:1zs93xkt] KeypadLinc will start to do a loud buzz, keep holding until the buzz stops [*:1zs93xkt] KeypadLinc will beep, reset to factory, and the attached load will turn on [*:1zs93xkt] In ISY Admin, right click on the KeypadLinc device and select "Restore Device" These steps worked for: [*:1zs93xkt] (2334-2) KeypadLinc Dimmer 5 Buttons v.43 [*:1zs93xkt] ISY Admin v.4.2.4
  5. Most of the rows say "Identical". But the last three say "Identical/Ignore". However when I manually compare all hexadecimal numbers, they match.
  6. First, forgive me if I use the wrong terminology. I have a KeypadLinc 2334-2 6 button keypad (reported in ISY as 5 Buttons v.43). Named "Front Door Switch" it shows up as: [*:245vbz0l]Front Door Switch [*:245vbz0l]Front Door Switch - A [*:245vbz0l]Front Door Switch - B [*:245vbz0l]Front Door Switch - C [*:245vbz0l]Front Door Switch - D The On and Off button (big ones at the top and bottom) control the internal dimmer connected to a stand-alone light. A is programmed as a controller for the light of the FanLinc. It works as expected (tap = on/off, double-tap = instant on/off, hold = dim/brighten). B is programmed as "Fan High" I set it as a toggle, so tap it once, fan goes on high and button B LED lights, tap it again both go off. It's also a controller for LED button C, which it turns off when button B is pressed. Button C is the exact same thing, except it's "Fan Medium." My problem is this: When I press the large bottom "Off" button on the KeypadLinc it will turn off the stand-alone light, and it will also turn off the LED of buttons B and C (but it will leave the fan on to whatever setting it was). I look at the "Front Door Switch" in the ISY, and it isn't listed as a controller for anything. And because a video is worth at least 33 words.... https://www.dropbox.com/s/3ng0em1q0cv25 ... .16.36.mp4 Thank you! B
