ejacobs
Everything posted by ejacobs
  1. I'm using an ISY26 and would like to do the following: I'd like to set-up a button on my keypadlinc that when pressed will turn on all of the kitchen lights, a total of 5 devices, and will turn them off when pressed. I know I can accomplish this with a scene, but. I also would like this button to respond in the following way - if the local switches in the kitchen are ALL turned on - the keypadlic button will light, but only if ALL of the lights were turned on. If the light is on on the keypadlinc and a local switch in the kitchen is turned off, the keypadlinc button light will turn off. I've tried a few methods of programs and scenes, but I know I must be missing something. Any help will be great.
  2. I'd like to have one of the buttons at the front door on my keypadlinc activate a security program. I want the program to turn all the interior lights on (not a problem, I can do that) And - I want all the exterior lights to flash. I have a scene that contains all the interior lights and another one that contains the exterior lights. I have one program that listens for the keypadlinc "security" trigger and then activates the "inside" program to turn the lights on and the "outside" program (from the then) to flash the exterior lights. The problem is, the outside lights just turn on and then off right away. The is the program: If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Set Scene ' All Outside' Fast On Set Scene ' All Outside' Fast Off Repeat Every 2 seconds Else - No Actions - (To add one, press 'Action') Any ideas?? I think it has to do with the repeat command, I don;t think it does what I want.
  3. I'd like to use the switchlinks in the bedrooms for two things - I can;t seem to get this to work the way I want. Normal use of the switch would operate the overhead light - no problem Fast On (Dbl Tap) would turn on another Insteon device in the room, but NOT turn on the overhead light, which is the load connected to the switch. Is this even possible?? The only way I figure to to do this is with the following program. The scene that is being triggered turns the table lamp on and then shuts off the overhead light. If Status 'Bedroom 1' is Off And Control 'Bedroom 1' is switched Fast On Then Set Scene ' Bedroom 1 Dbl Tap' On Else - No Actions - (To add one, press 'Action') This works, but the overhead light comes on until the program hits the line that says turn it off. Any ideas
