SteveG
  1. And that would be my problem! Seperated it and it worked like a charm. Just as a reference if anyone else stumbles upon this thread looking for an answer: Program 1: DoorUnlock If Control 'Front Door Lock' is switched Key/Manually Unlocked Or Control 'Front Door Lock' is switched Unlocked by Keypad Or Control 'Front Door Lock' is switched Remotely Unlocked Then Run Program 'LightOn' (If) Else - No Actions - (To add one, press 'Action') Program2 (Disabled so it only runs by the first programs call): LightOn If Status 'Front Door Entry Light' is Off Then Set 'Front Door Entry Light' On Wait 30 seconds Set 'Front Door Entry Light' Off Else - No Actions - (To add one, press 'Action') Thanks again MWareman! ~Steve
  2. Have a program that won't evaluate true when I think it should. Light is off and I am unlocking the door. If Status 'Front Door Entry Light' is Off And ( Control 'Front Door Lock' is switched Key/Manually Unlocked Or Control 'Front Door Lock' is switched Unlocked by Keypad Or Control 'Front Door Lock' is switched Remotely Unlocked ) Then Set 'Front Door Entry Light' On Wait 30 seconds Set 'Front Door Entry Light' Off Else - No Actions - (To add one, press 'Action') Can someone help me out with the above program? I just want to have the front entry light turn on temporarly when the door is unlocked, EXCEPT if it's already on. I am guessing I am messing up with the parenthesis but I am new and still getting the syntax down. Thanks, Steve
