boonest
Everything posted by boonest
  1. Thank you all. Java is now working on both of my machines. I followed MrBill's advice about deleting the Java folders in the AppData folder. I also edited the System Environment Variables according to the Wiki, again. With a fresh install of Java 64 bit I can now access my Polisy. Thanks again.
  2. So I have done everything in the Wiki, multiple times, with no change. I'm a little confused now. The Wiki says Java 64 bit but I thought it was supposed to be Java 32 Bit as Techman wrote. I am using a Polisy with v5.6.0 and PG3 v3.1.20.
  3. I have tried with the firewall disabled as well, no go. I will see if I can find other versions. I also scanned for viruses and machines are clean.
  4. Yes, I am using java from https://www.java.com. I followed all of the troubleshooting steps in the UD wiki and installed a previous version of Java 32 bit Version 8 update 351. Still no love.
  5. Not sure who to ask first, Java, Windows or Universal Devices. I chose to start here. I updated Java to V8u371 on my Windows 11 machine. Installation was successful. Now I get the following error when trying to run start.jnlp. When I click on 'Details' I get, which has the following text in the text box, java.lang.ExceptionInInitializerError at com.sun.deploy.net.protocol.https.Handler.openConnection(Unknown Source) at java.net.URL.openConnection(Unknown Source) at com.sun.deploy.net.BasicHttpRequest.createUrlConnection(Unknown Source) at com.sun.deploy.net.BasicHttpRequest.doRequest(Unknown Source) at com.sun.deploy.net.BasicHttpRequest.doGetRequestEX(Unknown Source) at com.sun.deploy.net.DownloadEngine.actionDownload(Unknown Source) at com.sun.deploy.net.DownloadEngine.downloadResource(Unknown Source) at com.sun.deploy.cache.ResourceProviderImpl.getResource(Unknown Source) at com.sun.deploy.cache.ResourceProviderImpl.getResource(Unknown Source) at com.sun.javaws.Launcher.updateFinalLaunchDesc(Unknown Source) at com.sun.javaws.Launcher.prepareToLaunch(Unknown Source) at com.sun.javaws.Launcher.prepareToLaunch(Unknown Source) at com.sun.javaws.Launcher.launch(Unknown Source) at com.sun.javaws.Main.launchApp(Unknown Source) at com.sun.javaws.Main.continueInSecureThread(Unknown Source) at com.sun.javaws.Main.access$000(Unknown Source) at com.sun.javaws.Main$1.run(Unknown Source) at java.lang.Thread.run(Unknown Source) Caused by: java.lang.SecurityException: No TLS/SSL protocol is enabled. at com.sun.deploy.net.protocol.https.Handler$Initializer.<clinit>(Unknown Source) ... 18 more This error appears on my laptop and desktop. Both are running Windows 11 Pro 22H2. Both start.jnlp and admin.jnlp produce the same error message. Everything was working prior to the Java update. I have rebooted computers, reloaded Java, deleted everything from Java including the applet. I downloaded and installed fresh applet from forum, and still, same error. One weird thing is that when I use the 'Java Uninstall Tool' it says that Java is not installed on this machine, even though I have both 32 and 64 bit versions installed. Maybe it is time for Universal Devices to implement an embedded web server.... just saying. Thank you in advance for any and all help and guidance.
  6. OK. It Works! Thank you very Much.
  7. Thank you so much for the speedy reply. I will give it a try later when at home.
  8. I just started programming my ISY994, I am still learning, and I have run into a mental dead end. This is my situation, I have a switch that turns on a light. When that light is on and I turn on the switch again, I want it to turn on a second light. When I try to program the first switch, the second light is turned on after the first tap on. I do not want to 'tap twice' the switch. The time between the two 'on's will vary, if at all. I am at a loss as to how to do this. Any and all help would be greatly appreciated, and thank you all in advance.
