chris87
  1. I will fix that now. Thank you for your help. Much appreciated.
  2. Is there a good wiki for this? I don't think I actually understand what I need to do to configure the controllers. I'm definitely more of a novice, and I don't have a lot of experience configuring the ISY.
  3. That's what was confusing me. The instructions say to Copy Scene Attributes, but I don't see where to do that.
  4. Yes, sorry, the load wire is capped off. Only hot, neutral, and ground are connected.
  5. I have the black and white wire to the hot and neutral from the ceiling line. The red wire on the fan controller goes to the black wire from the fan. The blue fan wire goes to the blue wire on the fan controller. I should have the picture up in a few minutes.
  6. I have version 5.0.16C. The KPL is wired to hot/neutral that I pulled to the box. It's not connected to the Fanlinc. I have the lights connected to the blue wire on the Fanlinc. Stupid question, but how do I copy the scenes to paste them here?
  7. I purchased a fan controller and keypad to use with a Hunter fan. I attempted to use the Wiki found here to program this, but I'm having issues: https://wiki.universal-devices.com/index.php?title=ISY994i:INSTEON_Device:FanLinc-KPL_FanLinc_KeypadLinc_Configuration I think that I did everything correctly, but I can't find the option to "Copy Scene Attributes from." The keypad has no LEDs on and doesn't seem to do anything if I hit the buttons. I tried activating one of the scenes within the administration panel and that also does not appear to work. What's odd is that one of the scenes actually turned the lights off on the fan, even though the lights aren't part of the scene. I don't understand how that can happen. I'm pretty sure that my wiring is accurate as it's color coded. When I control the fan/light directly from the fan controller within ISY, it seems to work fine.
  8. My sister just purchased a condo, and I promised her that I would put in some type of alarm system. I don't know the best option. She wants home automation for lights, front door, etc, so I was planning to use ISY/Insteon/Mobilinc. I suppose I could also use the Insteon Hub, but it seems like the ISY is more reliable. I use it personally, and it's been great. She has a second floor unit, so there is really only one point of entry (aside from the windows). Her needs are pretty simple, but I know she would want monitoring and a mobile app. I've seen different options like Abode, SimpliSafe, LiveWatch, and others, but I don't have any experience with them. I'm not even sure if it's worth integrating with ISY, as I feel like the standalone features are sufficient. I see that people like Abode, because it interfaces with Z-Wave. Does anyone have any ideas for a good option? I'm overwhelmed by all of the choices.
  9. Good suggestion, thanks! I will post over there.
