keithhawaii
  1. Is there a way for an ISY program to tell if a light attached to a ToggleLink relay was turned on locally? I have an Insteon motion sensor (2842-222) mounted looking across my back door. The outside backdoor light is controlled by a ToggleLink relay (2466S). I have the ISY994 programmed so that after dusk the light turns on when it sees motion and turns off 10 minutes after not seeing motion. I would like to include override logic in the program so if the light is turned on using the local ToggleLink switch the absence of motion after 10 minutes won't turn the light back off. I don't see the switch controller portion of the ToggleLink in the list of Insteon conditions for the ToggleLink device. Is there a way to tell if the switch on the ToggleLink relay turned the relay on? thanks, Keith
