mgs24
Everything posted by mgs24
  1. @NDSSM , Wondering the same thing. I have several that have failed. New ones are available but will probably do the same thing.
  2. I use the ISY portal and Mobilinc together just fine. I think what makes it work is I use port forwarding in my firewall along with my DYNDNS name https://*****.thruhere.net to get to my ISY. Hope that make some sense. -Mike
  3. Jimbo, the above change is to the 000 ButtonOff correct? Thought I was getting somewhere but still not working. When setting up the variables for first time all values are 0 to begin with? Thanks again, Mike
  4. If I trigger manually or thru ISY it works. Have you changed your programing at all since you began this tread 8/2013? I just at a loss why it worked so well and now all kinds of problems.
  5. I had been using Jimbo's programs successfully for several months then they stopped working. I have been working non-stop to fix. I have completely re-entered them. I then felt I may have some communication issues. I added 2 Range extenders. Nothing is working at this point. Is this still working for everyone? Has there been any updates or changes to the programs? Any help would be appreciated. I not sure how to read the logs but this is when it fails: Thu 07/16/2015 05:17:55 PM : [iNST-TX-I1 ] 02 62 00 00 1B CF 11 00 Thu 07/16/2015 05:17:55 PM : [iNST-ACK ] 02 62 00.00.1B CF 11 00 06 LTONRR (00) Thu 07/16/2015 05:17:55 PM : [D2D EVENT ] Event [34 DD 16 5] [sT] [255] uom=0 prec=-1 Thu 07/16/2015 05:17:55 PM : [ 34 DD 16 5] ST 255 Thu 07/16/2015 05:17:55 PM : [D2D-CMP 001E] STS [34 DD 16 5] ST op=6 Event(val=255 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> true Thu 07/16/2015 05:17:55 PM : [D2D-CMP 001D] STS [34 DD 16 5] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false Thu 07/16/2015 05:18:01 PM : [iNST-TX-I1 ] 02 62 00 00 1B CF 11 00 Thu 07/16/2015 05:18:01 PM : [iNST-ACK ] 02 62 00.00.1B CF 11 00 06 LTONRR (00) Thu 07/16/2015 05:18:18 PM : [iNST-TX-I1 ] 02 62 00 00 1B CF 13 00 Thu 07/16/2015 05:18:18 PM : [iNST-ACK ] 02 62 00.00.1B CF 13 00 06 LTOFFRR(00) Thu 07/16/2015 05:18:18 PM : [D2D EVENT ] Event [34 DD 16 5] [sT] [0] uom=0 prec=-1 Thu 07/16/2015 05:18:18 PM : [ 34 DD 16 5] ST 0 Thu 07/16/2015 05:18:18 PM : [D2D-CMP 001E] STS [34 DD 16 5] ST op=6 Event(val=0 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> false Thu 07/16/2015 05:18:18 PM : [D2D-CMP 001D] STS [34 DD 16 5] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Thu 07/16/2015 05:18:27 PM : [iNST-TX-I1 ] 02 62 00 00 1B CF 11 00 Thu 07/16/2015 05:18:27 PM : [iNST-ACK ] 02 62 00.00.1B CF 11 00 06 LTONRR (00) Thu 07/16/2015 05:18:27 PM : [D2D EVENT ] Event [34 DD 16 5] [sT] [255] uom=0 prec=-1 Thu 07/16/2015 05:18:27 PM : [ 34 DD 16 5] ST 255 Thu 07/16/2015 05:18:27 PM : [D2D-CMP 001E] STS [34 DD 16 5] ST op=6 Event(val=255 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> true Thu 07/16/2015 05:18:27 PM : [D2D-CMP 001D] STS [34 DD 16 5] ST op=1 Event(val=255 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false Thanks, Mike
  6. I have things all screwed up and now my Opener has stopped working from overheating. I am going to take a break from this and try again this weekend. If you come up with anything, or others have this working please let me know. Thanks again, Mike
  7. It is the icon status of my Open/Close program on my Dashboard. I assume the Dashboard is the same as favorites? Thanks for the help. -Mike
  8. I am going crazy trying to get the Icon correct. If the it is set to Garage Door the icon shows open when door is open, shows closed when door is moving, shows open when door is closed. Icon is revered when Garage Door Revers is selected. I just can't seem to get it to display opened and closed accordingly. Any ideas looking at my programing? Thanks, Mike
  9. Xathros, I am trying to setup my garage door in mobilinc but can't get my door icon correct. You say that what keeps the icon correct is to run the Else of the open/close program. There is nothing in the else portion of the open/close program. Am I missing something? open/close If $i_LDG_Status is 1 Then Set 'GarageLarge-Sensor / GarageLarge-Relay' On Wait 10 seconds Set 'GarageLarge-Sensor / GarageLarge-Relay' Off Wait 8 seconds Else - No Actions - (To add one, press 'Action') Status: If Status 'GarageLarge-Sensor' is Off Then $i_LDG_Status = 0 $i_LDG_Status Init To $i_LDG_Status Run Program 'LGD_OPen/Close' (Else Path) Else $i_LDG_Status = 1 $i_LDG_Status Init To $i_LDG_Status Thanks, Mike
