Ryan
Everything posted by Ryan
  1. Does anyone know where the ISY gets the information displayed in a Zwave door lock's "Alarm" section in the Admin Console? It typically shows text such as "Remotely Locked" or "Key/Manually Unlocked", and I would like to get this information via REST. I can easily get the status or battery level from "/rest/nodes", but the property with id "ALARM" always shows " " for both formatted and value (while at the same time, the Admin Console displays a readable string). How can I use REST to get what's shown in the Admin Console?
  2. Brian, Yes, I believe you're right about the "local-control-only" load sensing. I agree that a direct replacement probably isn't going to happen in this case. I'm glad to have a second opinion on this though. Thanks for your help!
  3. I have 2 very old Icon 2856D2B plug-in dimmers that I'm trying to replace with 2 new 2457D2 LampLincs. After adding the new dimmers to the ISY and removing both the old and new devices from their original folders, the new devices still don't show up as replacement options for the old devices. The new LampLincs are recognized by the ISY as "(B2457D2) LampLinc BiPhy v.43". The old ones show up as "(2856D2) Icon LampLinc 2 Pin v.38" -- notice the missing "B" in the detected model number. I understand that if the old dimmers were responder devices only, a direct replacement may not be possible. However, this model does have load sensing, even though the ISY doesn't show that it could be a controller. Were the old Icon dimmers improperly detected as the wrong model when they were installed? I don't even see "2856D2B" in the "New Insteon Device" type dropdown. Could these modules have load sense and still really not be controllers -- and therefore, I'm out of luck? I can go ahead and manually setup the replacement devices, but I'd like to make sure that I'm not missing something obvious before I do all that extra work... Can an Icon 2856D2B be automatically replaced with a 2457D2 or not? Any help would be appreciated. Thanks!
