hart2hart
  1. Reboot and it will go away. It’s a bug from one of later releases.
  2. Glad I could help.
  3. Reboot and it will clear.
  4. hart2hart replied to dakall's topic in Insteon
    As I recall, the number on switch likely refers to the hardware version. It might uptick if for example a larger capacitor was specified. eISY is reporting the onboard firmware version.
  5. hart2hart replied to GUdinsky's topic in ISY994
    Typically a reboot
  6. By name they appear time for a a portion of the If. Is your time zone set correctly?
  7. Green means the last time executed it was True and Red means it was False. The ones in Yellow are the ones you should look at.
  8. hart2hart replied to Techman's topic in eisy
    Done and good. Thanks.
  9. hart2hart replied to Techman's topic in eisy
    I too updated both an eISY r1 and r2 (in burn in mode). The only quick item I noticed was when opening PG3x dashboard it says IoX Version: 6.0.4 Connected instead of 6.0.5
  10. hart2hart replied to Techman's topic in eisy
    @Techman Great! Are there release notes posted? Nevermind. Found it.
  11. The name is likely in Alexa from the ISY if you had one.
  12. The automations as I recall are tied to the device. Sounds like you upgraded from an ISY or Polisy. Not sure if there is a way to move them over or you have to recreate them.
  13. Not from console that I’m aware. If it has a USB-C port on the back it’s R2. R1 had a regular USB port on the back.
  14. It’s been a few years since I started used these devices in scenes What I found was they became non-responsive over time but would work in scenes again if power was removed from them. Non I’ve got very inexpensive zwave devices that a program cycles power off and on each night. They work consistently in eISY scenes. Not elegant and not better than what you did but an FYI.
  15. I found a replacement battery for my first one. It’s really small and don’t recall details.
