PCRover
Everything posted by PCRover
  1. It was a bad connection to the PLM. I would never have thought the PLM could cause that kind of error. Thanks!
  2. That is not it. New fresh session, same results. Also I cannot delete the new scene unless there is a device in the scene. When empty I get a popup that says "TCP Client DNS Error" "dispatcher.mobilincconnect.com
  3. It doesn't matter what method I add a scene with, same result. "Authorization Failed" after it is added. My ISY is a factory installed Z-wave version and had a scene already added, but had no devices in it. I do not get the "Authorization Failed" with that scene. My new scene "Test Scene" has a Z-Wave wall outlet module in it for testing, but there is no difference in the results with various devices added to the scene.
  4. I am new to the ISY system and have run in to an odd situation when trying to work with scenes. When I create a new scene, then click on the name in the tree, The "ISY Finder" pops up and I get an authorization failed message. The Factory installed scene does not do this when I click on it. Then after hitting "Ok" on the error message if I do a "test scene", I get the same "ISY Finder" popping up and the "Authorization Failed" message but the test appears to process. Anyone know what is going on here?
