Methos000
Everything posted by Methos000
  1. Michael helped me, it ended up being a sync issue with the portal it seems. Logged out entirely and then was able to log back in and get it all connected up! Thanks for the ideas guys!
  2. Yeah, it is, i'll dig it up and ask him. Ty!
  3. Yeah it's in this state in the PG3 site. Is disconnected from ISY, but won't find the ISY automatically or when specified manually. (with http, or https. I've verified ports in the ISY console. It says a restart is required, but when I initiate it, it doesn't seem to happen. even rebooting the entire Polisy doesn't resolve that part. It doesn't seem like any configuration changes i make in the PG3 settings stick at all. I *can* connect to the ISY through Finder now though, it found it automatically after the flash.
  4. Got the thing reflashed and got the ISY back online. Polyglot3 is all sorts of messed up and I can't get it to reconnect to the ISY though. I need to find out how to set that part back to factory or something.
  5. Michael responded. It sounds like I've got really old OS on it (I bought it beta era) and need to reflash it to get it up to snuff. So I'll get crackin on that when i find my msata-usb adapter!
  6. Yeah, I get the XML <root xmlns="urn:schemas-upnp-org:device-1-0"> <script/> <specVersion> <major>1</major> <minor>0</minor> </specVersion> <URLBase>https://192.168.1.199:8443</URLBase> <device> <deviceType>urn:udi-com:device:X_Polisy_Device:1</deviceType> <friendlyName>ISY</friendlyName> <manufacturer>Universal Devices</manufacturer> <manufacturerURL>https://www.universal-devices.com/product/polisy-pro</manufacturerURL> <modelDescription>X_Polisy_Device:1</modelDescription> <modelName/> <modelNumber>5200</modelNumber> <modelVersion>5.4.4</modelVersion> <UDN>uuid:00:0d:b9:53:da:84</UDN> <UPC>uuid:00:0d:b9:53:da:84</UPC> <serviceList> <service> <serviceType>urn:udi-com:service:X_Polisy_Service:1</serviceType> <serviceId>urn:udi-com:serviceId:uuid:00:0d:b9:53:da:84</serviceId> <SCPDURL>/services.wsdl</SCPDURL> <controlURL>/services</controlURL> <eventSubURL>/eventing</eventSubURL> </service> <service> <serviceType>UDIZWaveWebServices</serviceType> <serviceId>uuid:00:0d:b9:53:da:84-UDIZWaveWebServices</serviceId> <SCPDURL>/zwaveServices.wsdl</SCPDURL> <controlURL>/zwaveServices</controlURL> </service> </serviceList> <presentationURL>/</presentationURL> </device> </root>
  7. Thanks for trying guys, much appreciated. Ticket time!
  8. Correct, I can reach that portal. I see the ISY configured, but it fails to send even a restart control to it. I don't even get far enough to enter credentials. Yes, I can ssh to it, but the login I use for other management stuff doesn't work.
  9. Launcher appears but doesn't find any ISY/Polisy devices. Even when manually adding them it fails to find them.
  10. Yep, sure do. I can reach it through the dashboard url, but unreachable through the java console at all. Is the Polisy "on the way out"? Should I just be upgrading to the new eisy? (i haven't done enough research on it yet to determine if it is, in fact, an upgrade)
  11. I'm at a loss right now, I can't the the java console to connect to my PolISY in any way. I can reach the Polisy dashboard though. Can't get it to boot ISY. Tried all the java clean out and reinstall tricks, hard rebooted... nothing. What do I do? I see nothing useful in the wiki at this point.
  12. Yeah, it does measure in the return air plenum. The problem is my house is new construction, and the return for both of the top two floors is on the main floor, other than the small segment in the master suite, and then the basement, which is extremely low due to radon mitigation. So the majority of return air, even when the top floor zone is running, all gets pulled from the main floor or basement where humidity is lower, or nearly non existent. I agree with the sentiment of not wanting to mess up my house, but the aprilaire controller has done nothing but mess my house up. Initially, by over humidifying the second floor (while set to the lowest relative setting), because it doesn't sample properly, and now, by not humidifying at all. So literally anything is better than what it has done.
  13. The on off does sound better, I don't need the sensor input on the IOLinc really. The ISY has local weather data if I recall, I know i was using it for sunset data in the past, but I'd probably use that if it works. If not I'll have to go back to the drawing board. The Aprilaire controller never did work very well, and I don't see how a new one would do it any better - the humidity measurement is in the basement on the furnace stack, and it often would hover in the 30% range, but on the top floor where everyone was sleeping it would creep upwards of 50% according to the Insteon thermostats. I live in Minnesota, so you can imagine all the condensation and ice build up that created constantly. I am actually kind of glad this controller crapped out so that I can come up with a real solution.
  14. Yeah the Insteon Thermostat actually has humidity built in, so I think I can trigger with those variables with ISY programming. I'm just not sure what hardware to trigger the 24v solenoid. I've been digging more myself and am thinking maybe I do it directly by eliminating the original controller altogether and directly triggering the solenoid with an I/O Linc. I just haven't tried cobbling together hardware in this style yet, but hypothetically I am starting to think it'd work though. Thanks!
  15. Hi, thanks for reading first of all. I've got a pretty well setup system for my whole house, over 100 insteon devices total, but the one nut I haven't figured out how to crack is getting humidification control integrated in a smart way. My hand is being forced by my Aprilaire controller's humidistat is no longer working, so it won't initiate humidification... so here I am trying to figure it out. What is the best way to do this? I'd like to eliminate the aprilaire controller altogether if possible. I have 3 zone HVAC, with insteon 2447's, so I already have indoor temp and humidity sensors on every floor, although the only one I'm really interested in is the top floor where bedrooms are. I know I can use the thermostat to do blower activation on demand, and I know how to do the programming aspect within the ISY, but I don't exactly understand how to wire the former humidistat/controller in a way that the ISY can engage the solenoid. What are your thoughts? What have you done? I've done some searches and seen some info in a couple other topics here but I haven't gotten the complete picture from it and didn't want to necro old threads. Thanks!
  16. Hi, Is there any way to adjust the text size in the admin console java app? I recently got a new laptop with a 3200x1800 resolution in a 15 inch screen. It looks amazing in nearly every application, but in the admin console the text size is nearly unreadable it is so small. Other applications seem to scale appropriately but this one doesn't. The command prompt is the only other app I've used that is all squinty-text. Thanks for your time!
  17. I like that rule of thumb, if you CAN use a scene to do it, then you are better off. ISY Failure and keeping some level of functionality is another great point I wasn't thinking of. That response speed makes a lot of sense too, i was wondering if i could cut out the latency of those door and motion sensors! I guess I was just taking the lazy way out since I didn't want to go around putting them all back into programming mode, but since there is a true benefit, i'll obviously go for it! Good stuff guys, thanks! I hope someone else finds this thread useful too.
  18. I may be in the minority here, but I find myself leaning very hard on Programs and virtually never use scenes so far. I'll admit that I've only owned my ISY for about 2 weeks, but I've got 44 dimmers, 5 hidden door sensors, 24 motion detectors, two thermostats, a couple KPL's and mini remotes, and I find that I've only created a couple scenes. I've found myself questioning if I am following best practices. What do you experts think? I lean the programming route heavily since my day job involves programming, so it comes simply natural to go that route. But would I be better served by using scenes? What are best practices? I did some searching but haven't found a topic that decisively answers that. Thanks for your time guys! I look forward to improving my setup.
