tycoonbob
  1. Hi all. Long story short, I helped a guy out with something, and in return he gave me this device (he knew I was looking to revamp my HA setup). So he couldn't tell me much about the device, since he didn't do much with it. He gave me the device, 2 Cat5e cables, and the power adapter. No Insteon PLM. I opened the device up and to my surprise I find what I think is the Z-Wave module (which I need, since all I have at this time is Z-Wave). Is this the Z-Wave module? I notice mine has a mini-USB port which I didn't see on the Z-Wave module wiki post.. So the problem I'm facing is that when I plug in the device to power, the Error light keeps flashing. According to the manual, this means a file system error. I took out the SD card (1GB microSD), dd wiped it, and popped it back in. Still blinks, but makes sense now. Problem is, the device is not pulling DHCP. If I plug a different device into that switch port, DHCP is pulling. For this device, it is not. So because of this, I can't access the UI to configure any of it. Any ideas? I see a microUSB port labeled "monitor"; can this be used somehow to set a static IP? Lastly, is there any problem with me wanting to run this without the Insteon PLM? For now, Z-Wave is all I care about. If I add Insteon devices later, I have no problem buying the PLM. Thanks!
