GinaGlidden
  1. Thank you, we followed your suggestions but unfortunately, we still get the same message, on 2 different computers. Any other ideas? Gina
  2. Xathros, I am having the same problem. I get the message : "Cannot save zip file". It has nothing to do with Mavericks on our end. Issue happens on OS X 10.7 and OS X 10.8. It works with Firefox. We searched the forum for the answer but came up empty handed. Would you happen to know what Safari download options and Java security settings need to be changed? Thanks, Gina
  3. Thanks Lee! That was the issue.
  4. Question: If I activate a responder (2477s) from a controller (2487s), the assigned button on the controller illuminates as a visual indicator that it is 'on'. Should the assigned buttons of all the controllers associated to this responder also illuminate? I have a scene with 3 controllers for 1 same responder. Button 'A' has been assigned as the controller on all devices. Each controller is in a different part of the house. When I activate the responder from 1 of the 3 controllers to turn it 'on', I thought the assigned 'A' button would illuminate on all controllers, so that no matter where I am in the house, I can see that the responder is 'on', but only the button on the controller I pressed is illuminated. Is there a way I can have all the assigned controller buttons illuminate? I hope this makes sense. Other than that, everything else works like a charm!!! We are thrilled! Thank you for your help.
