toy1
Everything posted by toy1
  1. Hi yes I got it to where I want it, I just picked the wrong line on the Motion sensor by mistake and never went back to recheck it thanks for your help it is really appreciated!
  2. got it I have been looking at this and just missed the problem seeing the issue sometime it is real obvious and I am looking for something else?
  3. Hi Xathros do not see how you change the state of the sensor once it is linked ? again thanks in advance for your guidance
  4. this is the program I am using if from Sunset to Sunrise (next day) and control Motion sensor -dust .dawn ups' is switched on then set 15.30.06 upstairs den light 1 fast on
  5. hi I opened the event viewer and this is what it states it appears every time I wave my hand it does the same 3 messages just the time changes. fri 1/09/2015 1:53:44 pm inst -srx 02 50 31.88.94 11.00.01 cb 06 00 fri 1/09/2015 1.53.44 pm std-group 31.88.94--. 13.00 01 cb 06 00 (00) fri 1/09/2015 1.53.44 pm inst -info previous message ignored I wish I could get a screen shot but this will have to do I can understand some of this info but not all
  6. hello to everybody on the forums, I have just converted my home automation over to isy994i ir pro model I was running for years using RBI home runner, I had issue with the system and was looking for better support. I have everything back up and running had to write some simple programs and ever things seemed to be working great, it took a day for me to adjust to different ways of doing things but ok , except for the insteon motion sensors, it appears they do not work or I am not getting signal or they are not set up properly, I reset each to factory default made sure jumper 5 is on and went thru the linking, I found a program that I felt would work and it appears not to work, when I walk into the room after sunset and before sunrise I want the light to come on and it does not, this has worked under my old system but it does not work here. any help would be appreciated.
