maui4marko
Everything posted by maui4marko
  1. Okay, thanks for the responses. Next trip here I will bring a couple Access Points. Will the LampLinc Dual-Band Lamp Dimmer Module work, or does it have to be the Access Point itself? Mark
  2. Hello, I just installed a Venstar T1700 1-Day thermostat and 2441V RF Adapter. Also, I have SignalLinc RF, not Access Point. I can't get it to link to ISY 99i (1020) with v2.7.0 firmware. When using Link Management | Start Linking, the Level 3 log says: [LNK-BGN ] 02 64 01 00 06 ---- Initializing the linked devices ---- ---- All Linked Devices are now initialized ---- [LNK-END ] 02 65 06 : : Unexpected, ignored (65) I tried the factory reset and it flashed the thermostat display, the light went out for a few seconds, and then came back on. When attempting to link, it *doesn't* flash the display (although the instructions says it will). Do you think I have a defective RF adapter? Are there any troubleshooting tips I can follow? Do I need a newer firmware version? Do SignalLincs work or does it require Access Point? Thanks Mark
  3. With v2.6.6 I have a timer set to "Sunset - 1 hour" (Honolulu time). When "sunset - 1" hour arrives, the condition becomes true but the timer doesn't actually activate until "sunset" with next scheduled run showing as "sunset". Am I doing something wrong or is this a bug? Mahalo, Marko
  4. Hello again Michel, thanks for your reply. Actually, I did try to upgrade previously on more than one occasion, but due to (presumably) network delays I have never been able to complete a remote upgrade successfully. I quickly learned doing things remotely is very difficult with ISY because for one reason or another, errors occur that halt the process. Therefore, it seems remote upgrades are not an option for me. I am physically unable to travel to the site more than once or twice a year, and thus am stuck without being able to upgrade until I am on site. Believe me, having upgraded to 2.6 on my other (local) installation I would much prefer having it in this install as well. The ISY is set to use static addresses already, so that is not the issue. Because of the environment the ISY is installed in, it is not easily accessible by my neighbor. On site help from him is strictly limited to power on/off via the breaker panel. Therefore, my only option is do whatever I can remotely. As a follow-up, I was able to get my neighbor to power cycle the ISY for me today. Following that, I was able to log in via HyperTerminal (but could not via the web interface). The menu showed up but the command prompt was 0.0.0.0:16590 rather than the usual address. Not sure what that means, but guessing its not good. Anyway, I tried one command "VE" to display the version and ISY then went away and never came back. At this point I'm guessing it will just have to wait until I can visit the site in person to bring it back to life and perform upgrades/reprogramming/etc in person. Thank you, Mark
  5. Just want to let you know I'm still receiving incorrect text in the notification (v2.6). The device transitioned from off to on, but the message is stating the opposite: On Alert! From: alerts@universal-devices.com To: xxx@nnn.net Subject: On Alert! Date: Dec 22, 2007 4:59 PM 12/22/2007 16:56:37: In Insteon Network At 7078 Russell Court: In the *Home Alone,On has changed to Off. *** Service Machine. DO NOT REPLY ***
  6. Recently at my remote installation a severe storm came through and the power was up and down (mostly down) for a period of 2 days. I could tell from my security cam logs that there were multiple on/off periods. Following this, ISY was dead in the water. Couldn't communicate with it via HTML or HyperTerminal. Normally, after a power outage ISY will properly reboot itself and everything runs fine. This time though, it seems like the rapid on & off (probably accompanied by spikes/brown-outs/etc) did a number on it (I'm surge protected on two different levels). I was finally able to get my neighbor over to power cycle it in a more orderly fashion. I was able to login using both methods, but response time was very slow and the entire system was quite sluggish. Probably due to network delays (3K miles away!) but no way to tell what has happened to ISY. The lights did come up with the initial schedule running (v2.4) but subsequent dim & off schedules did not run. Via the HTML interface it looked like the schedules may have been corrupted/deleted. I should have known better but attempted to reload my last backup version to see if that would help. Unfortunately, I could not get a clean reload due to continually erroring out. As a last-ditch effort, I logged in via HT and told it to reboot. Following that, ISY stopped talking to me and I can no longer access via either method. I'm trying to arrange to have my neighbor return for some troubleshooting, but unfortunately he is limited to only powering on & off. He does not have ability to do any local work on the system. So now to get to my point (sorry for the long-winded story) I'm wondering if there are any methods or techniques I could use to help me out of this situation in the future. I am already planning to install a UPS/battery backup, as well as a remote power control device that will allow power on/off cycling via the web. Thanks in advance for any thoughts on this topic. PS ISY has been remarkably resilient through many of these power outages, outlasting several other pieces of network and control equipment...but I'm always on the hunt for ways to improve it!
  7. maui4marko replied to maui4marko's topic in ISY994
    Thank you!
  8. Would this be a valid workaround? If From Sunset For 2 minutes Then Set Scene 'Exterior Scene' On
  9. Hello Michel, Oops, sorry forgot to clear the cache... it works now, but here are some comments: - Time is incorrect (off by several minutes) ... I assume this is due to your mail server clock difference - Text is incorrect: it states the On has turned to Off when in reality it was the other way around - Minor item but can the "In the" on line 3 be removed? Personally, I would prefer just listing the device name and the change in status. Or even better: give me a choice of my own text. This is from KPL button G/7 going from off to on: If Control '*Home Alone' is switched On Then Send Notification to All Thanks ... every thing else is checking out OK. Great job!
  10. When are the notification settings going to make it back in? Just installed 2.4.15 and still cannot save email/mobile settings.
  11. Is it possible to change the assigned port number? I have ISYs installed in multiple locations and for ease of administration I would like to be able to change the port number.
  12. maui4marko replied to Chuck's topic in ISY994
    Hello Michel, Well it's a moot point now, as my problem seems to have mysteriously fixed itself. Not sure of the cause, but just for the record: Yes, I was trying to add another device into a large scene. Every time I tried, I would get the "Request Failed" message. Here were the troubleshooting steps I followed: - Retried adding the device several times; Request Failed - Power off reset PLM; Request Failed - Reboot ISY; Request Failed - Power off PLM & ISY; Request Failed - Remove Scene, restore PLM, power off reset PLM & ISY, add scene; Scene devices added successfully until final (control) device; Request Failed At this point I gave up and posted to this forum. Today however (several days later) I tried again and was able to successfully add the scene as well as the previously troublesome control device to said scene! Seems kinda bizarre to me - not sure what would take place in the interim that would resolve the problem but whatever it was the problem no longer exists. FYI, per the link calculator I now have 432 links ... and growing
  13. maui4marko replied to Chuck's topic in ISY994
    I have a beta PLM with FIRM 56 and am having trouble creating a scene that brings me over 417 links. I thought 56 was supposed to handle appx 1000 links? I keep getting the generic "failed" message. I've used the ISY PLM Link Calculator and confirmed that my new scene takes me above 417 links. Any thoughts or tips on how I can find the root cause of my problem? Up to now, I've had no issues adding new scenes. Marko
  14. maui4marko posted a topic in ISY994
    Is there a list of error codes documented anywhere? Would be helpful to better understand the log.
  15. I apologize in advance if I missed the thread, but I seem to no longer be able to save email / cell addresses. I had this working in 2.4.12 but now when I add them, they show up on the right pane, and I can appear to save them...but if I exit ISY and come back to the Configuration tab the next time they are gone. I saw the post re: 2.4.13 fixes referencing the removal of notification settings from Configuration tab. Am I missing something or just in my usual late-night instefog? Trying to set up a Home Alone button that notifies me when my son gets home from school. TIA, marko
  16. maui4marko replied to maui4marko's topic in ISY994
    Michel - that fixed my problem...whoo hoo! Everything is functioning perfectly now. Thank you so much for your help on this one!! marko
  17. maui4marko replied to maui4marko's topic in ISY994
    Hi Michel - yes, I added devices using both methods. I will redo and let you know the results. Thanks! Marko
  18. maui4marko replied to maui4marko's topic in ISY994
    Michel, Thank you for being so responsive, especially during non-business hours. I'll post further tomorrow, but just want to clarify that these issues are only related to the devices that were "corrupted" during the original upgrade process. The other devices I have that were not affected are functioning normally both w/ISY and without. I'll do some more testing in the morning and post my specific scenario and setup so as to help with your diagnosis. Thx, Marko
  19. maui4marko replied to maui4marko's topic in ISY994
    Aloha Michel, I removed the responders and added back - no change. I know you said its not the PLM, but its almost as if it is remembering the corrupt links and cannot overcome that. Since the Broncos are totally choking, I spent some time today and did additional testing as follows: - removed all devices that were "corrupted" - did factory reset on all corrupted devices - did an ISY backup - removed PLM - factory reset ISY - power off ISY & PLM - reload 2.4.13 to ISY - reload saved settings - restore PLM My logic was to try to get back to a clean slate in trying to eliminate all traces of the corrupt devices. I then created a new test scene by adding corrupted/reset KPL & a couple corrupted/reset devices. Same behavior as before...KPL will not control scene. I then tried adding a corrupted/reset SL to control the scene to try to isolate if it was just the KPL or if it is all corrupted devices. Same result - SL could not control the scene either. As before, ISY will turn on/off the scene from the GUI but the controller device will not. That is why I'm thinking that the PLM is "remembering" the bad links and no matter what I try, I cannot delete or overwrite those bad links. I also tested whether manual links between the corrupt KPL & corrupt devices work, and they do. The KPL will properly control any of the devices via manual links. It is only when using scenes that it doesn't work properly. What's my next step? Mahalo, Marko
  20. Red italics indicate Controller (vs blue=Responder)
  21. maui4marko replied to maui4marko's topic in ISY994
    A related issue: The 2 KPLs (one in 6 button mode, other in 8 button mode) no longer "take" any scenes assigned to them. After setting it a scene and assigning the KPL as a Controller, it won't respond to button presses. The On/Off lights will activate, but the scene does not come on. ISY can turn on and off the scene, but I'd kinda like my buttons to do it too I have tried doing a Factory Reset on the KPLs to no avail. Have also tried Restoring the KPL, as well as the PLM. Could this be related to the PLM being a beta version? It is Firm 56 dated 8/15/07. Any suggestions on how I can get the KPLs functioning again with scenes? mahalo, Marko
  22. maui4marko replied to maui4marko's topic in ISY994
    I have 393 links as currently set up
  23. maui4marko replied to maui4marko's topic in ISY994
    I've got 39 devices installed and currently 19 scenes. I have the beta PLM which I think I remember supports ~1000 links. Some of my scenes have lots of devices, so is it possible I'm running up against the limit? I've only made a first pass at the scenes, so could probably reduce the number and complexity. Is there any way of telling how many links I have, through memory usage or other means? I do have more devices planned, so it will definitely be worth my time to fully understand where I sit in terms of usage. Thx, Marko
  24. maui4marko replied to maui4marko's topic in ISY994
    Some follow-up info: - ISY could control the devices, but the status always showed as Off - I had to remove the devices and relink them and then the status showed correctly - The devices remembered the previous ramp and on levels, but not ISY - I had to recreate the scenes from scratch After performing the above actions, ISY appears to be functioning normally
  25. maui4marko replied to maui4marko's topic in ISY994
    Ok, did the test and the Test scene is still there. The ones I lost were just created yesterday - I'm guessing that has something to do with it. Here's a screen shot after reboot. [/img] Earlier, I also tried doing a Factory Reset, reloading 2.4.13, and then reloading my saved config and same results.
