hutchyx
  1. hutchyx replied to brianp6621's topic in ISY994
    oh wow.. I'm glad I got it when I did. It worked perfectly here.
  2. hutchyx replied to brianp6621's topic in ISY994
    Universal Devices used to sell a Z-Wave Antenna Assembly (Item# 50005004). I don't currently see it on their site though. It worked perfectly. I was also working with a Schlage. None of the repeaters I bought worked although I didn't try the siren. I like the idea of having a siren in my system.
  3. but when the nodes default function isn't listed because the name is too long, renaming it isn't going to add that function to the end of the name.
  4. hutchyx replied to brianp6621's topic in ISY994
    The only way I was able to get my zwave door lock to be reliable was to replace my zwave antenna on the ISY.
  5. hutchyx replied to hutchyx's topic in ISY994
    I've read that. I can't even get the v41 sensors wet to turn on when they're sitting in a puddle.
  6. hutchyx posted a topic in ISY994
    I recently purchased a bunch of leak sensors. Some are v41 and others are v43. I understand the v43 sensors. I place the leads in water and the Wet node changes to On. I don't understand the v41 sensors. I can't seem to get the Wet node to activate when placing the leads in water. What am I missing here?
  7. Any chance you gave your leak sensors long names? If the name you gave them is too long, you won't see the dry, wet, heartbeat
