aawitek
  1. Yes.
  2. When i disabled the first device, the admin console froze. After restarting the computer, and trying to connect to the 994, through my browser by ip address, the "webpage is not available" error come up. When i double click the admin console icon on the desktop, nothing happens now, it wont open.
  3. I have switches with both the red ! and green 1011 next to them, and the "system busy" loop is still going. My system was working perfectly fine until i did the firmware upgrade. I have not added any electrical devices at all.
  4. My answers are above. Also, i recently moved the PLM to a different outlet with nothing else plugged in. I still get the same looping "system bust" and now there are "can not communicate" errors with some devices.
  5. My answers are underlined above.
  6. After disabling just the one light, the log looks clean, no errors and the issue is still there. I did a factory reset. I tried to reprogram all of my devices from scratch, however, when linking them i get communication errors and am unable to link, or they aren't even detected.
  7. I disabled it and the same system busy loop is occurring. Additionally, now the green "writing" symbol is now shown next to a different switch. The switch is only controlled with a scene.
  8. It is a dimmer switch. Prior to updating the firmware this issue was not happening. I see the event log and it indicates a system error number -1 which apparently is a request failed error.
  9. I upgraded my ISY 994i firmware to 4.2.18. Now when in the admin console a system busy window pops up. The progress bar of the system busy window goes from 0 to 100%, it closes, then it starts up again. I left the admin console open over night and the opening/closing cycle does not end. The text at the bottom of the system busy window reads: [ 2B D2 E1 1] DOF 1 Also, since upgrading, all my lights will flicker. It is not a constant flicker, they flicker once every 2 minutes or so. Has anyone encountered this or has a solution? Thank you.
