GTCJ
  1. Mine has worked flawlessly for years, but when I started researching this I see a lot of encouragement to using gmail account. I have so many email accounts now to keep track of I hate to add another, but perhaps that's the way to go. Thanks for the assistance.
  2. The test message is an e-mail sent to a text address. The programs with notifications have been working for years and the only thing that has changed is the versions and the "mail server error". I only have 1 e-mail message and one destination. Not sure how that could be wrong in a program.
  3. Ever since moving from 4.7.3 to 5.0.16C every time I start the admin console I receive an error message that says "Mail Server Error". For 7 years I have used the default SMTP settings and have a group that would send via e-mail a text message to an Android device. Was amazingly fast when it worked, but now I receive no notifications from programs. Test message works flawlessly and immediately. Any assistance in resolving this would be appreciated. Thank You
  4. GTCJ replied to GTCJ's topic in ISY994
    Very good - thank you
  5. GTCJ replied to GTCJ's topic in ISY994
    Prior to removing the unused devices from service, I put each in DISABLE mode. To ensure my understanding, they should stay in DISABLE when I hit DELETE?
  6. GTCJ replied to GTCJ's topic in ISY994
    That count also includes a lot of inventory that was used seasonally in the PST but is sitting in bins. I think I will delete all of those devices to start with and reassess. I appreciate your help and insight. thanks again
  7. GTCJ replied to GTCJ's topic in ISY994
    When I run a topology report and copy into a spreadsheet it takes 357 lines. I noticed that keypads and other devices with sub devices have a line for each sub device. There are about 25 keypads, 20 motion detectors and 9 water sensors. That would account for about 230 of the lines. Am I wrong to assume each sub device counts towards the actual device total?
  8. GTCJ replied to GTCJ's topic in ISY994
    Actually, the link count I gave you was from the PLM. Sorry about that.
  9. GTCJ replied to GTCJ's topic in ISY994
    I'm thinking it doesn't ever get the Query All done. After your reply I ran it and at 3 minutes and 10 seconds, it showed 30% complete and then stopped. And my link count is 1057. Something has changed I think, I haven't really added anything other than a couple of remotes in several years. Last time I did the count it was under 500. Looks like I have some work to do.
  10. GTCJ replied to GTCJ's topic in ISY994
  11. GTCJ posted a topic in ISY994
    I recently upgrade from 4.7.x to 5.0.16c. I have noticed that if I query all from top of tree it takes several minutes to go through the device list. Was considerably faster under older firmware. Is this normal.? Approximately 300 devices in system. Second question. Have searched extensively but cannot find link capacity for ISY994i pro.
  12. GTCJ replied to GTCJ's topic in ISY994
    Thank you for the reply. I will look for that thread. Was hoping in the several years since I first saw it a cure would have been found.
  13. GTCJ posted a topic in ISY994
    Fairly large residential installation. If sub devices of keypads, motion detectors etc are included approximately 300 devices. Periodically, almost every device, lights, ceiling fans etc will turn on simultaneously to full fast on. This always happens when a motion detector is triggered. I removed the one I thought was offending, but then another picked up the behavior. None of the motion detectors are linked to devices. They all are used to trigger programs that trigger scenes. None of my programs or scenes encompass all devices and very few would result in a fast on, full brightness condition. Almost all ramp up to the 50 - 70% level. There is no X10 in the system and the transformer that serves the house is not shared with any other structures. The log will always show the devices changed state always preceded by a motion "on". (1st gen 2420M) devices. After 7 years of this, I am confident the source of the all on trigger are motion detectors. The suspect detectors had fresh alkaline batteries. I'm willing to upgrade the 20 motion detectors to the 2844-222. Has anyone had similar experience and were the newer motion detectors involved?
  14. GTCJ replied to GTCJ's topic in ISY994
    Watched carefully, those were the only two messages received.
  15. GTCJ replied to GTCJ's topic in ISY994
    I haven't seen any other message, but will attempt again and watch closely. I am using the prescribed ISY Launcher.
