copperstar
  1. Thanks. Opened a ticket so waiting for help there. Tried several different supplies, all high amp, no help. I can watch the boot process on HDMI, boot stops at command line, can log in as admin. Several lines during boot of WARNING: failed to start isy. Trying to search for command line update commands and process but no luck.
  2. EISY BRICKED: Conducted update from counsel. Waited for reboot required. Selected reboot. Eisy does not complete startup and no entries in finder. Unplugged for several minutes several times and no change. Plugged in HDMI to monitor boot process. Several lines of WARNING: failed to start isy. Tried factory reset, no help. Unable to access isy now Any suggestions??
  3. Ended up deleting then reinstalling elk nodeserver and all is well. Must have been something that I did :). Thanks again for the great product and for trying to help.
  4. After an upgrade packages run, the Elk nodeserver is having problems. After several restarts and even a restore to previous, I continue to get ; Controller:handler_start: Timed out waiting for handlers to startup Although the NodeServer in IoX displays connected, there is no data available from the Elk NodeServer. Any ideas on restoring the server? Thanks Full error log below; 2023-11-17 19:14:42,977 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2023-11-17 19:14:42,979 MainThread udi_interface INFO __init__:<module>: UDI interface initializing 2023-11-17 19:14:42,980 MainThread udi_interface INFO __init__:<module>: User=000db953d8b0_1 2023-11-17 19:14:42,980 MainThread udi_interface INFO __init__:<module>: Home=/var/polyglot/pg3/ns/000db953d8b0_1 2023-11-17 19:14:42,981 MainThread udi_interface INFO __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/000db953d8b0_1 2023-11-17 19:14:42,982 MainThread udi_interface INFO __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MGQ6Yjk6NTM6ZDg6YjAiLCJwcm9maWxlTnVtIjoxLCJsb2dMZXZlbCI6IkVSUk9SIiwidG9rZW4iOiI5dStoVm5hZHVYQURnJkx1IiwibXF0dEhvc3QiOiJsb2NhbGhvc3QiLCJtcXR0UG9ydCI6ODg4Mywic2VjdXJlIjoxLCJpc1BHM3giOnRydWUsInBnM1ZlcnNpb24iOiIzLjIuMTYiLCJpc3lWZXJzaW9uIjoiNS43LjEiLCJlZGl0aW9uIjoiU3RhbmRhcmQifQ== 2023-11-17 19:14:42,983 MainThread udi_interface INFO __init__:<module>: Loading interface module 2023-11-17 19:14:43,576 MainThread udi_interface INFO interface:<module>: Loading MQTT module 2023-11-17 19:14:43,791 MainThread udi_interface INFO interface:<module>: MQTT module loaded 2023-11-17 19:14:45,615 MainThread udi_interface INFO __init__:<module>: Loading udi_interface module 2023-11-17 19:14:45,620 MainThread udi_interface INFO __init__:<module>: Loading node module 2023-11-17 19:14:45,621 MainThread udi_interface INFO __init__:<module>: Loading custom module 2023-11-17 19:14:45,621 MainThread udi_interface INFO __init__:<module>: Loading isy module 2023-11-17 19:14:45,622 MainThread udi_interface INFO __init__:<module>: UDI interface initialized 2023-11-17 19:14:45,623 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.2.4 Starting... 2023-11-17 19:14:45,902 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.2.16 [ISY: 5.7.1, Slot: 1] 2023-11-17 19:14:45,904 MainThread udi_interface.interface INFO interface:__init__: Connect: Network Interface: {'addr': '192.168.0.19', 'netmask': '255.255.255.0', 'broadcast': '192.168.0.255'} 2023-11-17 19:14:45,908 Interface udi_interface.interface INFO interface:_startMqtt: Connecting to MQTT... localhost:8883 2023-11-17 19:14:45,914 MainThread udi_interface.interface WARNING interface:db_getNodeDrivers: controller not found in database. 2023-11-17 19:14:45,915 Interface udi_interface.interface INFO interface:_startMqtt: Using SSL cert: 000db953d8b0_1.cert key: 000db953d8b0_1.key ca: /usr/local/etc/ssl/certs/ud.ca.cert 2023-11-17 19:14:45,916 MainThread udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2023-11-17 19:14:45,918 MainThread udi_interface.interface INFO interface:addNode: Adding node ELK Controller(controller) [None] 2023-11-17 19:14:45,919 MainThread udi_interface.interface INFO interface:setController: Using node "controller", driver "ST" for connection status. 2023-11-17 19:14:46,017 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with result code 0 (Success) 2023-11-17 19:14:46,020 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:0d:b9:53:d8:b0_1 - MID: 2 Result: 0 2023-11-17 19:14:46,066 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2023-11-17 19:14:46,149 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2023-11-17 19:14:57,444 Thread-8 udi_interface ERROR Controller:handler_start: Timed out waiting for handlers to startup 2023-11-17 19:14:57,448 Thread-8 udi_interface ERROR udi_interface:write: Exception in thread 2023-11-17 19:14:57,449 Thread-8 udi_interface ERROR udi_interface:write: Thread-8 2023-11-17 19:14:57,450 Thread-8 udi_interface ERROR udi_interface:write: : 2023-11-17 19:14:57,451 Thread-8 udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2023-11-17 19:14:57,452 Thread-8 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 980, in _bootstrap_inner 2023-11-17 19:14:57,460 Thread-8 udi_interface ERROR udi_interface:write: self.run() 2023-11-17 19:14:57,462 Thread-8 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 917, in run 2023-11-17 19:14:57,472 Thread-8 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs) 2023-11-17 19:14:57,483 Thread-8 udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db953d8b0_1/nodes/Controller.py", line 167, in handler_start 2023-11-17 19:14:57,492 Thread-8 udi_interface ERROR udi_interface:write: self.exit() 2023-11-17 19:14:57,493 Thread-8 udi_interface ERROR udi_interface:write: AttributeError 2023-11-17 19:14:57,494 Thread-8 udi_interface ERROR udi_interface:write: : 2023-11-17 19:14:57,495 Thread-8 udi_interface ERROR udi_interface:write: 'Controller' object has no attribute 'exit'
  5. Looking forward to testing the app on Evo 4G. Would not mind at all paying for it once out of beta. Thanks for the hard work.
  6. Thanks again for the very quick response. As an update, I just deleted the 2 EXIO2x4's from my ISY and re-installed them and they seem to be working fine now. Both the garage door and the motion detector are receiving instantaneous signals now. I will keep you advised if any further problems. I am new to the ISY, previously running Homeseer with the insteon plug in, now testing the ISY99 plug in for homeseer. Thanks again...
  7. Thanks Micheal for the update. Is there an insteon input device that you know of that does give a reliable reading to the ISY. Thanks again for your help on this.
  8. Are there any updates to this known problem. I have 2 EZIO2x4's for garage door status and motion detection and am not able to use either without performing a manual query. Thanks...
