pauldugas
  1. Something started working later. The Ring NS changed from Disconnected to Connected and I got the blue link to authorize. Did so and I see the nodes now. Still not getting anything from the OpenWeatherMap one - Disconnected.
  2. Oh, nothing at all in Details > Real-Time Log for the Ring NS in the Polyglot Cloud UI. Also, getting the same Current Status: Disconnected with the OpenWeatherMap NS I'm trying to tinker with to.
  3. I'm looking at trying to get the same thing going. ISY running 5.0.15 is connected to the portal and I can get into the Polyglot cloud and see that the portal NS is there (Current Status: Unmanaged). Added the Ring NS from the Store but it reports Current Status: Disconnected and I don't get anything under Details > Configuration for logging into Ring. I see Ring in the list of Node Servers (slot 3) in the admin console. What am I missing?
  4. I'm leaning toward the phantom voltage being the issue. Going to reach out to some EE friends to see if there's a way to filter that out. A little surprised it's not handled properly in the module actually. All assuming my read of the situation is correct of course...
  5. The checkbox in the Device Options panel labeled "Momentary: (Off) Latching" is unchecked. I believe this indicates it's in latching mode already.
  6. I have a hand full of the Insteon Micro Dimmer Modules installed behind switches in my place. Most work perfectly. One seems to think the switch input is toggling on its own. The switched input to this one is a 3-way and I'm wondering if something odd may be confusing the sense input. Has anyone here had a problem with these units in a setup like this? Diagram of the circuit attached. I've ohm'd out everything and it's wired correctly. My digital meter reports odd AC voltages on the SENSE input to the dimmer module which I suspect are caused by phantom voltage on the return from switch-2 which is in the same piece of romex wire as the travelers. I suspect this is where the problem lies but I'm not sure how to fix it.
  7. Can you confirm that when calling the disabled programs, you are running the IF and not just the THEN or ELSE?
  8. I'm pretty sure this used to work. Will investigate and test more thoroughly. Thanks for the sanity check, Paul
  9. I have a line in the THEN clause of a program that runs another program's IF/THEN/ELSE but that other program is disabled. The Last-Run time for the second program is updated when the first one runs but it's not actually running the program. Is that the expected behavior? I disable the second program so it would not be scheduled to run on it's own but I assumed that I could still explicitly run it from other programs. Guess that's not the way it works.
