ta2four
Everything posted by ta2four
  1. Good Morning. We had 2 power bumps this morning and one of my light switches didn't like it. It is a 6-button Insteon 2334-232. On the first use after the power bump the light associated with the main LOAD from the switch would come on slowly (as if it was ramping up) and go off/on at a dim level every second (or maybe even faster). I pulled out the reset pin and pushed it back in holding it in until the switch beeped (steady on). From that point the switch would beep on every button click (which it didn't do before). I main light associated with the switch would not turn on when I pressed the top button. However, I have an "All On" button on the same 6 - button switch and the light would come on when I pressed the "All On" button (so it is not a disconnected load wire). From the ISY I set all the options associated with the device to "ON" and then to "OFF" and compared the Links Table (which matched). I then did a "restore device" from the ISY. This cleared the "beep" when I clicked the buttons but did not fix the issue with the ON (top button) not turning the light on. Incidentally, the "OFF" button doesn't work either (It is programmed to do run the "All On" scene - setting it to OFF). So, I'm guessing circuitry associated with the MAIN LOAD on the switch got fried by the power bump. All programming/scenes associated with the 4 middle buttons seems to work (FAN, Night Light, All ON, Center Light). Before I replace the switch I thought I'd ask you guys what you thought. Thanks! Also, if you have a second, what is the easiest way to replace a 6-button switch on the ISY with a new one (this will be the first time I will be doing this). ISY994i (running V4.9.0)
  2. lol... go figure. What are my options exactly? is there a upgrade path that doesn't require that I "resync" all of my devices and rebuild my scenes and programming?
  3. I deleted a few devices (a lamp controller and two remotes I wasn't using) and was able to add 2 devices without issue. So, it would appear that I did hit a limit of some sort. I haven't programmed the devices yet, but at least I got them added. I'll look into upgrading to a PRO ISY device. Is replacing the ISY with a PRO version as simple as doing a backup and restore? or is there more to it?
  4. Yep. I'm with you now. I brought the lamp module (on phase1) halfway to the non-working devices (on Phase 2) and tested the lamp module to make sure it was still getting signals over the extension cord. No issues there. Linking the new devices still failed. So, I guess I'm at the point of taking one of the switches out of the wall, moving it closer to the network and seeing if it will sync at all. ugh. I have some new switches in a box. Maybe i'll try one of those first. I'm spent for today. Thanks for your help. I may not get back to this tomorrow (or until next year) but since I had your ear it was worth giving it a try today.
  5. Great. Thanks. I have a range extender but I don't think I'm using it correctly. I put it near to the devices that were not working (on phase2) but I suspect it was too far from other devices and plm (on phase1) to bridge the gap. However, I moved it (keeping it on phase2) but closer to the plm. I think this should have worked, but it didn't help, unfortunately. Is a PLM/ISY device reset required to sync everything up again? I'm out of ideas now. (Not sure what you mean by "Try temporarily bridging one of the new switches near your working ones and try again". I could put a lamp module on the end of an extension cord plugged into phase1 and bring that lamp module closer to the devices on phase2 that are not working (is that what you are getting at). I can't move the switches that aren't working any closer to the plm or the phase1 network since they are wired into the wall (lol).
  6. Thanks. I wasn't expecting that the device would be completely plug-n-play. Not sure what " 4 Tap" is... no need to explain unless it is easy to do so. I'll trust that it is completely plug-n-play. After plugging the repeater back in, I tried to add one of the switches that was failing with reason = 1. It still fails so the repeater didn't help. Tried a factory reset on the switch by pulling out the tab and then pressing it in for 10 seconds. Still didn't help. I tried putting the switch into linking mode before putting the isy into linking mode. With the device flashing green I put the isy into linking mode. In this state the ISY doesn't find the device at all. Not sure if that's helpful in debugging. Another thing that may be important... I have two electrical panels in my home... I have devices on both panels that are connected to the ISY and they work fine. I was originally surprised by this but I guess they are getting the signal via RF instead of the PLM?? Forgive me if I got the terminology wrong. Anyways, all of the devices that are failing are on the panel that IS NOT connected to the PLM. My guess is that the RF signal isn't strong enough to traverse the 100' to the nearest switch on the panel with the PLM. This may explain the issue but doesn't really explain why I was able to get one switch to link. If the double-electrical panel is the issue, how do I bridge across the two neutrals so that the devices will all communicate correctly? Is there are special insteon product that does that?
  7. I plugged in the "2922-222 Insteon Plug-in Range Extender, Repeater and Access Point" and tried to link it. The ISY found it but gave me an "Unsupported device:0.29" error. The failure reason in the event log was reason 10. Let me know what you think when you have time.
  8. Yep. That's my thinking too. The old devices are at most 12 years old. The new devices could be brand new (1 year) or at most 5 years old - sitting in a box-unopened until they were installed a 6 months ago. I have a spare PLM. The original PLM died many years ago but was able to solder in some new capacitors (etc - can't remember what I replaced off the top of my head) to get it working again so I never used the PLM I bought to replace it. Maybe I'll try to find the "Line booster" or whatever it was that I bought... and install it. I tried level 3... "failed to add device - reason 1"
  9. I tried both ways. The "Automatic way" (clicking on the "start linking" button and then pressing the tab on the switch until it beeps) gets me to a point where the device shows up in the list. Then when I click "Finish" it says failed to add. I added a screenshot.
  10. Ok. I'm on board with that! This is a relatively low priority item right now and I have 10 other things in my life that are causing me grief right now so I really don't need to blow away my smart lighting on top of it! Thanks for the heads up. If the devices should link without the firmware update then I'll avoid the extra headache. The new devices that I'm trying to add are quite a distance from the isy and/or plm. I purchased a signal booster at one point and haven't installed it yet so maybe I will try that. Having the devices show up on the ISY when I "link" them but raise an error when I try to "add" them is puzzling. Could it be that they are too far away from another device that is already mapped? Having said that, I was able to link one device a few months ago and the new devices that do not link are inches away (basically in the same switch bank). The device that I was able to link is the same (2477D V.45). Any thoughts on how to debug it would be helpful.
  11. Thanks. I have 477. So should be ok, I guess.
  12. Thanks. I'm not using z-wave... hopefully it is not a requirement to use my new switches. Since I'm not using z-wave, I really hope that I don't have to worry about the possibility of "rebuilding your network" talked about in the notes section. I have lots of switches, scenes and programs that would take months to rebuild. I was actually wondering if I hit the limit on the number of switches that I can add to the ISY. Is there a limit?
  13. Hi, First question: How do I upgrade my isy994i(1120)? A link to the firmware would be great. I'm currently running v4.9.0 I'm trying to add some new devices and most of them are failing to be added. Not sure if the devices are "too new" for the firmware. One device, a 6 button KeypadLinc gets added but the "A", "B", "C", "D" buttons don't show up. The device (according to the isy) is a: 2334-2 KeypadLinc Dimmer 5 Buttons v.45. However only one device is added (the A,B,C,D buttons are not added) when I click add. The other devices are just regular 2477D Dual band SwitchLinc Dimmer v.45. When I click "Finish" the "Status" in the "New Insteon Devices" window changes to "Add Failed" and the only error I get is "Cannot Add Insteon Device". Not sure if there are logs I can look at to figure out why it is failing. A link to the trouble shooting guide would be helpful. I'm hoping that this is a firmware issue and upgrading the firmware will fix the problems. Thanks for your help. Let me know if you need screenshots.
  14. Thank you.
  15. Thanks for confirming this Andy. It is not entirely obvious that this is what was happening, but my solution and your comment confirms it. In other programming languages, when you are inside of the "THEN" or "ELSE" clause of an IF---THEN---ELSE statement the programming language would not re-evaluate the IF "Condition" again inside a WHILE or REPEAT loop. However, there are certainly cases for wanting this, but the condition is usually listed as part of the REPEAT block and not in the outside block.... That is, the language syntax would normally be "IF <condition> THEN <statement> ELSE <statement>" And a "REPEAT" is another statement that COULD be implemented as: REPEAT <statements> WHILE <condition> Where <condition> in the REPEAT loop is not the same as the <condition> in the IF statement. But here the implementation of the REPEAT statement is using the same condition of the IF statement... which to me is rather bizarre. Is there any documentation for the language syntax that the ISY is using?
  16. In order to implement my feature I had to write 4 programs (see below). Basically I moved the REPEAT Loops into a separate program and called them from controller programs. ---------- Program 1: Call Tim Control Off If Control '**003 Living Room Pots / 003H Call Tim' is switched On And Status '**003 Living Room Pots' is Off Then Run Program 'Call Tim Leave Off' (Then Path) Else - No Actions - (To add one, press 'Action') -------- Program 2: Call Tim Control On If Control '**003 Living Room Pots / 003H Call Tim' is switched On And Status '**003 Living Room Pots' is not Off Then Run Program 'Call Tim Leave On' (Then Path) Else - No Actions - (To add one, press 'Action') -------- Program 3: Call Tim Leave Off If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Repeat 5 times Set '**003 Living Room Pots' On Set '**003 Living Room Pots' Off Wait 1 second Else - No Actions - (To add one, press 'Action') ---------------- Program 4: Call Tim Leave On If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Repeat 5 times Set '**003 Living Room Pots' Off Set '**003 Living Room Pots' On Wait 1 second Else - No Actions - (To add one, press 'Action') --------
  17. Hi, I have an ISY994i and I'm running firmware version 4.2.18. I'm new to programing ISY. I recently created the following program which was intended to flash lights 5 times: ------- If Control '**002 Kitchen Pots' is switched On Then Repeat 5 times Set '**003 Living Room Pots' On Set '**003 Living Room Pots' Off Wait 1 second Else - No Actions - (To add one, press 'Action') --------- The program above worked fine. The lights would flash 5 times and be turned off. I then wanted to augment the program to leave the light in the same state that it was before I started flashing it. I created two programs (one that checked if the state was already OFF) and the other that checked if the state was NOT OFF. ---------- If Control '**002 Kitchen Pots' is switched On And Status '**003 Living Room Pots' is Off Then Repeat 5 times Set '**003 Living Room Pots' On Set '**003 Living Room Pots' Off Wait 1 second Else - No Actions - (To add one, press 'Action') --------- and the second program: --------- If Control '**002 Kitchen Pots' is switched On And Status '**003 Living Room Pots' is not Off Then Repeat 5 times Set '**003 Living Room Pots' Off Set '**003 Living Room Pots' On Wait 1 second Else - No Actions - (To add one, press 'Action') ---------- The issue here is that the REPEAT loop is only executed once. The lights only flash once. Any ideas? Thanks, Ta
  18. Thanks... you answered one of my questions... how to add program statements AFTER a repeat block.
