stevewier
  1. I found that mwesters work around of adding the buttons to a scene as responders and then setting the scene state to "On" works well. So far, all my non-toggle On buttons are staying in on the On state. Thanks for the follow up.
  2. Prior to running this trace, I added all the buttons to a scene and turned the scene On. All the LED's are at level 15 as I wanted. However, I did run the trace.... Mon 11/30/2015 06:51:07 PM : [iNST-SRX ] 02 50 3B.8E.85 00.00.03 CB 11 00 LTONRR (00) Mon 11/30/2015 06:51:07 PM : [std-Group ] 3B.8E.85-->Group=3, Max Hops=3, Hops Left=2 Mon 11/30/2015 06:51:07 PM : [D2D EVENT ] Event [3B 8E 85 3] [DON] [0] uom=0 prec=-1 Mon 11/30/2015 06:51:07 PM : [ 3B 8E 85 3] DON 0 Mon 11/30/2015 06:51:07 PM : [D2D-CMP 001B] CTL [3B 8E 85 3] DON op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Mon 11/30/2015 06:51:07 PM : [D2D-CMP 0019] CTL [3B 8E 85 3] DON op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Mon 11/30/2015 06:51:07 PM : [iNST-SRX ] 02 50 3B.8E.85 33.5E.50 40 11 03 LTONRR (03) Mon 11/30/2015 06:51:07 PM : [std-Cleanup ] 3B.8E.85-->ISY/PLM Group=3, Max Hops=0, Hops Left=0 Mon 11/30/2015 06:51:07 PM : [iNST-DUP ] Previous message ignored. Mon 11/30/2015 06:51:07 PM : [iNST-SRX ] 02 50 3B.8E.85 33.5E.50 41 11 03 LTONRR (03) Mon 11/30/2015 06:51:07 PM : [std-Cleanup ] 3B.8E.85-->ISY/PLM Group=3, Max Hops=1, Hops Left=0 Mon 11/30/2015 06:51:07 PM : [iNST-DUP ] Previous message ignored. Mon 11/30/2015 06:51:07 PM : [iNST-SRX ] 02 50 3B.8E.85 11.01.03 CF 06 00 (00) Mon 11/30/2015 06:51:07 PM : [std-Group ] 3B.8E.85-->11.01.03, Max Hops=3, Hops Left=3 Mon 11/30/2015 06:51:07 PM : [iNST-INFO ] Previous message ignored.
  3. In looking at this further, it's as though the set to non-toggle On mode is not updating the "Current State" of the buttons. I added the four buttons into a scene as responders with no controller per mwesters suggestion. I then switched the scene to "On" and all four non-toggle On buttons status went to "On". I suspect a bug in the ISY994i firmware since the KPL responds to an On State command. Perhaps the code to update the KeyPadDimmer is missing the "turn the state to On' when setting the button to Non-Toggle On. My firmware version information is attached.
  4. If you look at the attachment in one of my previous posts, you will see that they are configured non-Toggle On. However, I did look at the status of the buttons and they are all "Off" which would make sense with the LED light setting. I tried setting them to non-toggle off and the current state remained at "Off" . If you look at your non-toggle On buttons, what is the current state?
  5. mwester, The logic sounds solid! I will give that a try and provide some feedback.
  6. I believe the firmware is v.45. I get two blinks and then the LED sets to the OFF level of 7.
  7. I have two that are configured the same way and behave in the same manner. Both are brand new (ordered from smarthome) and were factory reset prior to programming and again after programming (factory reset and restored) when the LED lights on button A-D would not go to level 15 when set to non-toggle ON mode. I was hoping the lights would work like the images in the Sonos thread http://forum.universal-devices.com/topic/11716-insteon-and-sonos-with-isy-994i
  8. I confirmed the buttons are set to Non-Toggle On.
  9. If I set the brightness at Off=7 and On=15 for the KeyPadLinc, that does function as expected an all the buttons are set to Off=7 and On = 15 or whatever settings I choose. However, buttons A-D are at level 7 even though they are in non-toggle On mode. I would like them to be at level 15 always. Any ideas?
  10. I have buttons A through D set to toggle on mode and would like them to stay lit/always on. I tried setting the on level to 7 and off level to 15. I'm not sure what that settings is for but it did not work. Is there another way to set the led to always on for these buttons? Thank you Steve
  11. I am interested in the same functionality for the same application. The IOS Sonos App has an alarm function with sounds. It might be possible to play one these tones. Have you found any solutions?
